u bolts
#913324
10/29/08 03:30 PM
Guys I need a pair of U Bolts for 5 inch lift springs on the rear of an 85 runner. All I can seem to find is the rounded ones and I need the squared off ones. Any ideas on where to find them? .....Thanks.....Brian
Re: u bolts
[Re: 4runnermedic]
#913325
10/30/08 12:12 AM
In the "help" section of the auto parts stores? They have some different u-bolts.
If all else fails, theres a place here that bends up custom ubolts. Maybe they will ship to you? Its called Brighton Spring.
Re: u bolts
[Re: 4runnermedic]
#913326
10/31/08 10:49 PM
Looks like there's two spring shops in your relative area. Either should be able to bend ubolts. Roanoke Auto Spring Works, Inc is right in Roanoke, and Salem Spring Works in (oddly enough) Salem. Trailer and heavy truck supply stores are another possible source. I see there's a Valley Heavy Duty Truck Alignment also in Roanoke that might be a place to try.
~Adam  96 T100: D44, lockers and stuff
Re: u bolts
[Re: adam]
#913327
11/01/08 06:20 PM
Tamendous....Thank you gentelmen
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6013 MB (Peak: 0.6569 MB) Data Comp: Off Server Time: 2026-06-07 04:41:04 UTCValid HTML 5 and Valid CSS
