Page 1 of 3 1 2 3
Gen 1 - Front suspension question #913365 10/29/08 05:49 PM
RocLimer Offline OP
I don't think I've come across this problem in the forum anywhere.
When I have the steering cranked over to make a hard left turn I get a metallic pop or grinding sound from the front passenger side axle assembly area. It also happens in lighter turning but when I am making a sudden suspension raise/drop i.e. a large curb sized obstacle (4-6"). I would like to fix this problem if possible before I do any trailing as I would hate to have something break while on the trail.
Any thoughts?
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: Gen 1 - Front suspension question [Re: RocLimer] #913366 10/29/08 06:43 PM
DREDnot Offline
sound like the early signs of a CV joint failing.
Are the boots cracked or split?
Raise that side up and with the wheel cranked hard over, spin the wheel and listen for the noise while checking the deep folds of the boots for splits.
It might not make the noise without being under load,though.
91 Montero LS,3.0L,auto,off road pkg.
89 Trooper S,2.6L,5 spd
07 Dodge Ram 2500 4x4,5.9L Turbodiesel,6spd
"Non Vi Sed,Arte"
Re: Gen 1 - Front suspension question [Re: DREDnot] #913367 10/29/08 07:01 PM
RocLimer Offline OP
I look at the CV boots regularly as I know the problems that can happen if a CV boot isn't repaired quickly. The boots are not cracked and are not/have not leaked any grease since I have owned the truck.
Re: Gen 1 - Front suspension question [Re: RocLimer] #913368 10/29/08 07:12 PM
ball joint perhaps? could also be worn anti sway bar rubber grommets.
Re: Gen 1 - Front suspension question - Single POP? [Re: RocLimer] #913369 10/29/08 07:17 PM
Q
Quixotic Offline
Is the noise just a single "POP", or does it continue to grind as you turn?
89 Raider V6, manual, 5.29 gears, ARB front locker
Re: Gen 1 - Front suspension question - Single POP? [Re: Quixotic] #913370 10/29/08 07:25 PM
hazy_daze Offline
Sounds more like the steering stops.
Re: Gen 1 - Front suspension question - Single POP? [Re: hazy_daze] #913371 10/29/08 07:29 PM
RocLimer Offline OP
It's more of a pop. It doesn't continue to grind but will pop again after 5 to 10 feet if I'm making a larger turn and don't back off on the steering. I've check for clearence issues and any sort of rubbing and I don't see anything. It's a pretty loud sound. Is is possible its a tie rod end or something like that?
Re: Gen 1 - Front suspension question - Single POP? [Re: RocLimer] #913372 10/29/08 07:31 PM
RocLimer Offline OP
The sway bar rubber is good on the bar itself, but is almost gone and cracked through on the bar ends on both sides of the vehicle.
Re: Gen 1 - Front suspension question - Single POP? [Re: RocLimer] #913373 10/29/08 07:41 PM
DirtDriver Offline
I think Hazy's got it. Take 2 minutes to put a dab of grease on your steering stops and see if the noise goes away.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Gen 1 - Front suspension question - Single POP? [Re: RocLimer] #913374 10/29/08 07:43 PM
It's the steering stops. When at full steering lock, there's a plate on the (a arm?) and an adjustable bolt stop to limit the steering turn on the spindle(?) that move in relationship to each other as the suspension cycles in the bump. When new, there's a rubber boot on the bolt end, and you're supposed to grease the end where it rides on the stop to eliminate the pop sound. You can either grease the bolt head or the plate stop to eliminate/lessen the sound, or just live with it. Use waterproof grease...
I've never tried to find a new boot, but the dealer may be able to get one.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6382 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-06-07 04:39:11 UTC
