option code G80 what works in '90 Trooper #913387 10/29/08 06:14 PM
Smorticvs Offline OP
I have a '90 Trooper, non-abs, and I've located a possible LSD donor. I have found a '93 Trooper, a '98 Trooper and a Vehicross at a local junk yard with option code G80. All are abs equipped. Will any or all of these work in my non-abs '90 Trooper? And if any will fit, do I need to make any modifications to accomodate it?
Thanks,
Steve
Re: option code G80 what works in '90 Trooper [Re: Smorticvs] #913388 10/29/08 07:18 PM
bamashooter Offline
The 93 will definitely work. Not because of an ABS issue, I'm not 100% sure about the other 2. The 93 is a different size and I'm not sure about the Vmobile. Same ratio as yours, right?
Re: option code G80 what works in '90 Trooper [Re: bamashooter] #913389 10/29/08 07:48 PM
I am assuming that they are all 4.55 gears, as the other (4.77, I think) are very rare. One thing I noticed is that the Troopers with abs have some kind of sensor on the 3rd member at the top, while the Vehicross does not, but appears to have them at the wheels. I'd like to use the one from the Vehicross, as it has the least amount of mileage (and doesn't have the sensor on the 3rd member).
Re: option code G80 what works in '90 Trooper [Re: Smorticvs] #913390 10/29/08 10:03 PM
BigSwede Offline
Isn't the VX a 4.30 ratio? Not sure...
I would think the third member from the 93 would work; the tone ring for the rear ABS shouldn't matter to you. Or just find one that came with 4 wheel ABS.
Serenity now!
Re: option code G80 what works in '90 Trooper [Re: BigSwede] #913391 10/30/08 12:32 AM
bamashooter Offline
The sensor atop the third member is the abs sensor; no big deal. As BigSwede pointed out, the Vcross is a different ratio (4.30).
Re: option code G80 what works in '90 Trooper [Re: bamashooter] #913392 10/30/08 03:04 AM
Jim_Paget Offline
Just realize that you are talking about a 15 YO LSD. It may very well be worn out. The cost of rebuilding one will outweigh the cost of buying a new, aftermarket LSD.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: option code G80 what works in '90 Trooper [Re: Jim_Paget] #913393 10/30/08 04:23 AM
Van Offline
Tha ABS/sensor should not be an issue as you have nothing to hook it up to... i.e. ABS computer or hydraulic control unit.
What you need to look at is the correct gear ratio and axle width as your front end.
Also, as mentioned... is it cheaper to buy a new one or go through the trouble of removing both axles from both vehicles only to find out that the "new" axle LSD is wore out... not to mention your time spent doing all this. <img src="/forums/images/graemlins/scared.gif" alt="" />
Thoughts to ponder. <img src="/forums/images/graemlins/confused.gif" alt="" />
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: option code G80 what works in '90 Trooper [Re: Van] #913394 10/30/08 03:32 PM
The junkyard has rear ends for $50/car and $70/truck. Not bad. If the rebuild cost is under $200, then this would be a very good bargain. I was planning on putting a locker in the front, once I got the lsd straightened out in the rear. I believe this would greatly improve the ability of the truck in sand and mud, but maintain good street manners. One other question to those who know... should I put a locker in the front, how would this affect steering while in 4wd?
Re: option code G80 what works in '90 Trooper [Re: Smorticvs] #913395 11/03/08 06:20 AM
Van Offline
It will be more difficult turning when locked in the front, but if you have manual hubs, simply unlock one if you're making hard turns (anything more than about 1/2 turn of the steering wheel)... be advised it will also make your front end prone to sliding sideways on slippery surfaces if you're off camber.
HTH
NEVER give up...
Re: option code G80 what works in '90 Trooper [Re: BigSwede] #913396 11/15/08 11:27 PM
A
apbt3178 Offline
Where can I find the RPO code sticker on a '95 Rodeo?! There's one about 5mins from my house, but I can't find the RPO codes anywhere!
PHP: 7.4.33 Page Time: 5.223s Queries: 15 (2.698s) Memory: 0.6318 MB (Peak: 0.7399 MB) Data Comp: Off Server Time: 2026-10-24 03:20:47 UTC
