22r stalling #913432 10/30/08 01:15 AM
thxgoon Offline OP
After driving for about 2 minutes today the engine just completely stopped running and it will not restart. There is fuel in the float bowl so at first I thought it was not a fuel problem but am beginning to think this may not be the case.
Truck is '87 22r carbed. Just replaced air filter and fuel pump about a month ago. What would cause it to just quit like that?
Re: 22r stalling [Re: thxgoon] #913433 10/30/08 01:51 AM
kewlynx Offline
Has it been rattling at startup before this?
Quick-n-dirty check- pull the distributor cap off; crank engine. If the rotor doesn't turn, you've lost your timing chain.
Check your fuses and do a good visual inspection to see if anything is amiss.
**ubi apis- ibi salus**
Re: 22r stalling [Re: thxgoon] #913434 10/30/08 05:04 AM
Buck Offline
Ignition took a dump gets my vote. I had a Jacobs unit die on me twice, now I'm back to a stock ignition.
84 Ext. Cab Pickup.
Re: 22r stalling [Re: Buck] #913435 10/30/08 07:13 AM
thxgoon Offline OP
That's what I was thinking... I sure hope it's not the timing chain!
How do you trouble shoot the ignition to find the faulty component?
Re: 22r stalling [Re: thxgoon] #913436 10/30/08 08:03 AM
kewlynx Offline
Go to the FSM sticky here and follow the instructions for the online library and login. To rule out the TC will take you all of 5 minutes.
Re: 22r stalling [Re: kewlynx] #913437 10/30/08 09:58 AM
thxgoon Offline OP
Given that I can crank the engine all I want without any strange noises or other catastrophic failures, I'm pretty sure the timing chain is ok. But I will take your advice and double check.. Thanks for the help.
How do you eliminate various parts of the ignition system? I'm a bit weary of touching the coil and what not because of the high voltages.
Re: 22r stalling [Re: thxgoon] #913438 10/30/08 10:33 PM
Buck Offline
Pull a spark plug and set it against the block with the wire connected to it and have someone crank the engine while you look to see if it's sparking. If not, check to ensure you have your 12v going to the coil pack and check the pickup from the distributor to make sure it's sending the signal to the coil pack to fire.
84 Ext. Cab Pickup.
Re: 22r stalling [Re: Buck] #913439 10/31/08 01:38 AM
thxgoon Offline OP
Pulled the dirstibutor and did the timing chain check and it is okay, but the distributor cap and rotor looked pretty worn so I went ahead and replaced them. I hooked up a timing light to the #1 plug wire and got no flashing so I'm pretty sure it is a spark issue. Thanks for the advice Buck, I'll take a look at the wire from the distributor tomorrow.
Is it possible that the governer could have failed causing the enging to stall? I was trying to figure out what all of the wires do that are connected to the coil and they seem to come from 3 different places.
Re: 22r stalling [Re: thxgoon] #913440 11/01/08 12:57 AM
thxgoon Offline OP
Well.... I checked everything as per the FSM and the coil, ignitor, wires all check out okay. Power is there, fuses are good, all connections are free of corrosion, but still.... no spark. Anyone have any other ideas? How do you test the distributor sensor on the distributor? Thanks for anything
Re: 22r stalling [Re: thxgoon] #913441 11/02/08 09:36 PM
Scerb Offline
Unplug the wire going from the coil to the distributor and see if it sparks when you crank the engine over..
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6331 MB (Peak: 0.7563 MB) Data Comp: Off Server Time: 2026-07-14 00:02:38 UTC
