Gen 2 power antenna #913523 10/30/08 04:53 PM
E
exp500 Offline OP
Hi Gang, while on a quick run thru the woods, I learned the importance of turning off the radio to lower the antenna. Any good fix Ideas? Can the mast be replaced by itself? Anyone else had to do this fix or am I the only stoopid one? <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Gen 2 power antenna [Re: exp500] #913524 10/30/08 05:06 PM
bOURGE Offline
Yes you can replace the mast itself.
1995 Montero SR
1999 Montero
1974 Ford Bronco
Re: Gen 2 power antenna [Re: exp500] #913525 10/30/08 10:47 PM
RocLimer Offline
Is it possible to add one of these to a Gen 1?
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: Gen 2 power antenna [Re: RocLimer] #913526 10/31/08 12:13 AM
Adding would be easy. The trickier part might be the power and it it prewired. If not, you'll need to rig it up.
Re: Gen 2 power antenna [Re: MontyMcV] #913527 10/31/08 01:34 PM
hazy_daze Offline
I've got a power antenna in mine. I was puzzled at how to install it at first, but after I just got into it, it took less than an hour to get done. Only thing I wish I had done was install a switch so I could control it, instead of having to turn the radio off.... but it's on my list of to-do's <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Gen 2 power antenna [Re: hazy_daze] #913528 10/31/08 02:25 PM
Angelo Offline
I had a detailed step by step fix on how to do this, including pictures. I sent it to Scottie, but not sure if he still has it too. I'll have to dig deeper and locate the file if you are still interested? Not too hard to fix, just takes about an hour to fix. Just let me know or shoot me an e mail. [email]APKouts@aol.com.[/email]
Re: Gen 2 power antenna [Re: Angelo] #913529 10/31/08 04:53 PM
RocLimer Offline
Hazy. Any possibility of a brief write up on how to wirre it to the radio? A few pics might be nice.
Re: Gen 2 power antenna [Re: RocLimer] #913530 10/31/08 06:58 PM
hazy_daze Offline
I replaced my stock radio with an aftermarket one. If you want to keep the stock radio, you could wire it directly off the battery to a switch then to the antenna. If you want to do it right, put a relay in the circuit. As far as the actual install, just remove the inner fender liner and everything is right there. Hardest part was fishing the cable from behind the ECU.... <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: Gen 2 power antenna [Re: hazy_daze] #913531 10/31/08 08:01 PM
Cochese Offline
I so have to go pull a power antenna from a GenII on my next days off!
1987 Dodge Raider TSi
...it begins.
Re: Gen 2 power antenna [Re: Cochese] #913532 11/01/08 03:30 PM
JAVYPRO Offline
Sorry to hijack but since you are talking about radios I wanted to inquire, do any of you have a spare factory radio knob that you are willing to sell?
On mine, the back part broke a little bit so I took it off to fix it with some JB weld but I put it in a place so secure that now I can't find it <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6378 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-07-17 04:38:39 UTC
