Weber 34mm DGEC - fuel leakage issue #913591 10/30/08 08:40 PM
Shirebourn Offline OP
I installed a new 34mm DGEC and the darn thing leaked fuel from the accelerator pump diaphragm area. I replaced the diaphragm, and the darn thing still leaked. I sent the unit back to the reseller, and the new one they sent me did the same exact thing.
Anybody else have this issue? Is it a known issue?
Thanks,
Re: Weber 34mm DGEC - fuel leakage issue [Re: Shirebourn] #913592 10/31/08 04:17 AM
ryany Offline
Years ago I had the accelerator pump diaphragm fail on the Weber DGV on my Opel GT while driving from AZ to Minnesota. It wasn't leaking externally, just wouldn't squirt when you accelerated.
95 Montero SR
Re: Weber 34mm DGEC - fuel leakage issue [Re: Shirebourn] #913593 10/31/08 04:46 AM
weebur Offline
Check your fuel pressure from the pump to the carb. The Weber carbs like to run between 2 1/2 to 3 psi. Stock pumps on the 2.6 (your signature doesn't indicate what engine) are rated between 2.8 and 4.2 psi. Too much pressure can cause leaks. See my recent reply to a post (Weber Conversion).
'97 Jeep Cherokee XJ, Country, Black/Gray Leather, 4.0L, 4WD Command-Track, AW-4 Auto, 3.55:1 Gears, PowerTrax No-Slip Locker, Hi Country Tow Brackets, Spectre Air Filter, 235X75R15 Goodyear Wranglers, 126K miles
Re: Weber 34mm DGEC - fuel leakage issue [Re: weebur] #913594 11/04/08 01:14 AM
THANKS!
Yes, it was a "too much fuel" issue. I got an adjustble, gauged regulator and dialed it right in.
I totally appreciate your help.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6007 MB (Peak: 0.6562 MB) Data Comp: Off Server Time: 2026-06-22 23:05:00 UTC
