Weber 34mm DGEC - fuel leakage issue
#913591
10/30/08 08:40 PM
I installed a new 34mm DGEC and the darn thing leaked fuel from the accelerator pump diaphragm area. I replaced the diaphragm, and the darn thing still leaked. I sent the unit back to the reseller, and the new one they sent me did the same exact thing.
Anybody else have this issue? Is it a known issue?
Thanks,
Re: Weber 34mm DGEC - fuel leakage issue
[Re: Shirebourn]
#913592
10/31/08 04:17 AM
Years ago I had the accelerator pump diaphragm fail on the Weber DGV on my Opel GT while driving from AZ to Minnesota. It wasn't leaking externally, just wouldn't squirt when you accelerated.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: Shirebourn]
#913593
10/31/08 04:46 AM
Check your fuel pressure from the pump to the carb. The Weber carbs like to run between 2 1/2 to 3 psi. Stock pumps on the 2.6 (your signature doesn't indicate what engine) are rated between 2.8 and 4.2 psi. Too much pressure can cause leaks. See my recent reply to a post (Weber Conversion).
'97 Jeep Cherokee XJ, Country, Black/Gray Leather, 4.0L, 4WD Command-Track, AW-4 Auto, 3.55:1 Gears, PowerTrax No-Slip Locker, Hi Country Tow Brackets, Spectre Air Filter, 235X75R15 Goodyear Wranglers, 126K miles
[Re: weebur]
#913594
11/04/08 01:14 AM
THANKS!
Yes, it was a "too much fuel" issue. I got an adjustble, gauged regulator and dialed it right in.
I totally appreciate your help.
