Turn Signals #913708 10/31/08 02:26 PM
morgueman Offline OP
Took 1989 Raider out last night for first test run and have all lights lit up but even with new turn signal switch and flasher, the turn signals will not work. Any ideas as to what I may have missed.
Re: Turn Signals [Re: morgueman] #913709 10/31/08 04:31 PM
Grasscat Offline
It may be the emergency signal switch that's giving you the problem. Try another and see if that fixes you problem, did on mine.
Michael j
TreadLightly! Trainer
Re: Turn Signals [Re: Grasscat] #913710 10/31/08 04:50 PM
RocLimer Offline
What's new that you did? Did you replace all your marker bulbs with led's? If so you need to use a high capacity turn signal flasher.
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: Turn Signals [Re: RocLimer] #913711 11/02/08 02:05 AM
No LED's but new T/S switch and flasher and new bulbs in all locations
Re: Turn Signals [Re: morgueman] #913712 11/02/08 08:40 AM
torquemonster Offline
chances are it is your hazard light switch...the signal lights do nothing unless its plugged into a working switch.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6048 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-06-22 11:20:14 UTC
