Turn Signals
#913708
10/31/08 02:26 PM
Took 1989 Raider out last night for first test run and have all lights lit up but even with new turn signal switch and flasher, the turn signals will not work. Any ideas as to what I may have missed.
Re: Turn Signals
[Re: morgueman]
#913709
10/31/08 04:31 PM
It may be the emergency signal switch that's giving you the problem. Try another and see if that fixes you problem, did on mine.
Michael j
TreadLightly! Trainer
Re: Turn Signals
[Re: Grasscat]
#913710
10/31/08 04:50 PM
What's new that you did? Did you replace all your marker bulbs with led's? If so you need to use a high capacity turn signal flasher.
Re: Turn Signals
[Re: RocLimer]
#913711
11/02/08 02:05 AM
No LED's but new T/S switch and flasher and new bulbs in all locations
Re: Turn Signals
[Re: morgueman]
#913712
11/02/08 08:40 AM
chances are it is your hazard light switch...the signal lights do nothing unless its plugged into a working switch.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6048 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-06-10 01:47:43 UTCValid HTML 5 and Valid CSS
