Center gauges #913713 10/31/08 03:30 PM
morgueman Offline OP
Is the angle gauge int the center suppose to be liquid filled or is it suppose to wobble like the hula girl figure in a riviera
Re: Center gauges [Re: morgueman] #913714 10/31/08 04:21 PM
Bernoulli Offline
It's supposed to be filled. They eventually leak. They can be repaired with RTV and any of a variety of liquids. Use the search function and you'll find options.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Center gauges [Re: morgueman] #913715 10/31/08 04:23 PM
Welcome to the wire. I'm sure you're already finding there's a wealth of info here on your Raider (aka rebadged 2 door Mitsubishi Montero).
The inclinometer is supposed to be filled with a fluid but with age the fluid typically leaks out because there is an elastic expansion 'membrane' that gets brittle with age... (at least that's the latest take on it).
Regardless, there's a write-up (Here) on how to fix it. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Center gauges [Re: off-roader] #913716 10/31/08 05:39 PM
ghostraider Offline
you know ...i looked at that "fix" . it is not very detailed at all. A thourough Post is needed for those who are not expireienced!
Re: Center gauges [Re: ghostraider] #913717 10/31/08 05:48 PM
What is missing to be thorough? The only thing left out was how to pull the center pod...
Re: Center gauges [Re: MontyMcV] #913718 10/31/08 10:54 PM
PartyTruck Offline
Throw it away and replace it with something more usefull like a voltmeter,trans temp or oilpressure.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Center gauges [Re: MontyMcV] #913719 11/01/08 01:38 AM
ghostraider Offline
I am sorry. <img src="/forums/images/graemlins/frown.gif" alt="" />
i did not mean to be rude in any way.
I just thought that it could be more step by step for the mechanically challenged is all. <img src="/forums/images/graemlins/kewl.gif" alt="" />
The post is fine by itself for me as i can repair anything. <img src="/forums/images/graemlins/kewl.gif" alt="" />
but my Girlfriend wouldn't know what to do or where to start based on that ONE picture with a brief description. <img src="/forums/images/graemlins/scared.gif" alt="" />
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Center gauges [Re: ghostraider] #913720 11/01/08 02:10 AM
PHIL_ Offline
Well, I put two pics in. I didn't think anyone actually needed to see more than one of a removed unit?
But if you figure it needs more detail, then why haven't you written a new article? Methinks if you don't contribute, you have no room to complain.
Re: Center gauges [Re: PHIL_] #913721 11/01/08 03:24 AM
ghostraider Offline
I am on it....i am going to do that and a speedo repair thread too...at least if i get up off my lazy butt!
thanx bro...YOU ROCK! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Center gauges [Re: ghostraider] #913722 11/01/08 04:35 AM
PHIL_ Offline
If you wanna send it to me, I can edit it into a full blown article to go in the tech section. Few pics would help. If you want to do it via pm that's cool, or pm me for my email addy... <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6406 MB (Peak: 0.7471 MB) Data Comp: Off Server Time: 2026-06-20 18:03:10 UTC
