alignment questions
#913784
11/01/08 09:19 PM
Installed new upper and lower ball joints (Toyota parts)on my 87 4Runner. Now my camber is now off and different left and right. Toe in is off also, but only a little. I want to try the shade tree alignment I've seen here on the web. 1) How to check caster? 2) FSM shows the direction to move cams for 'increase' and 'decrease'. I think the illustration shows the driver side, so I assume the opposite direction for the pass side? Probably dumb question. When they say 'increase, they mean wheel tilting in at top/out at bottom? 3) How much travel is the in these cams? What is a small or large adjustment as far as degrees of movement of the indicator dot/hole on the cam ? I'd like to give it a go myself as my past experience has not been good with tire/alignment fools around here. Anyone know where the article I saw a few years ago may be that shows one guy's method involving bending some sheet metal to a right angle and putting it against the front wheels. If I remember correctly that write up looked pretty good. Situation now is the front right seems to have too much camber and the left has almost none (measuring with a level against the wheel). Truck pulls to the right and has a wobbly feel sometimes. Feels like the right side.
Re: alignment questions
[Re: MAC]
#913785
11/01/08 09:28 PM
[Re: philly]
#913786
11/02/08 05:19 PM
How do I measure caster? Or where exactly do I eyeball it? Caster adjust (front/back cam relationship) will drastically effect toe, yes?
[Re: MAC]
#913787
11/02/08 05:43 PM
Caster angle is one thing that is hard to check with DIY tools, at least with IFS. - http://www.cadvision.com/blanchas/54pontiac/alignment.htmlMight be worth having an alignment shop give it a shot. On a solid axle, you can measure the spring perch or steering arm angle to get an idea of caster angle. Might see if you can find a spot to measure the angle on the steering control arms to get a relative angle between the two sides.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6032 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-10-21 17:08:38 UTCValid HTML 5 and Valid CSS
