Vibration on PreRunner #913941 11/02/08 06:00 AM
Renee Offline OP
Have a '01 Prerunner, have had the tires/wheels rotated and balanced still has a vibration. The carrier bearing has a little play in it, could this be the problem? Thanks.
Re: Vibration on PreRunner [Re: Renee] #913942 11/03/08 04:31 AM
Denvertaco Offline
Could be lots of stuff..I had issues with my carrier bearing, but that was right after lifted it, try a different shop and have it aligned first. An alignment could tell them if youve got some worn parts that can vibrate... <img src="/forums/images/graemlins/kewl.gif" alt="" />
03 Double Cab TRD.. ARB, warn winch, OME coilovers, Alcan leafs, Bilstiens, Sky E-locker guard, etc, bla bla bla
Re: Vibration on PreRunner [Re: Renee] #913943 11/03/08 03:37 PM
Mark in AZ Offline
Toyota Moderator
How long have you been using these wheels/tires?
Exploring in a T4R Ltd V8
Re: Vibration on PreRunner [Re: Mark in AZ] #913944 11/03/08 09:14 PM
Renee Offline OP
About a year when all of this started. I had it aligned, balanced and new rear shocks put on last week. It is better but there is still a little vibration I feel on the armrest and now in the accelerator. THe carrier bearing supposedly has a little movement in it. The truck used to ride pretty well for a small truck.
Thanks.
Re: Vibration on PreRunner [Re: Denvertaco] #913945 11/03/08 09:14 PM
Renee Offline OP
Thanks. I just had it aligned and balanced, new rear shocks. This ahs been going on about a year. Even bought new rims and tires. I has not been lifted any. It is better after all of this was done last week but there is still some sort of shimming on the armrest and now I feel it in the accelerator some. There is a little movement in the carrier bearing but don't want to spend $400 if that's not the fix.
THanks....
Re: Vibration on PreRunner [Re: Renee] #913946 11/04/08 01:43 PM
ACES_HI Offline
If you feel vibration in the steering wheel its the front tires out of balance. If you feel it up through the floor and seat then its likely the rear drive shaft. Have you checked your u joints for slop? They more often than the carrier bearing are responsible for vibration. Sorry to hear that you already dumped a pile of money into tires/wheels and shocks when they probably were never the problem. <img src="/forums/images/graemlins/frown.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Vibration on PreRunner [Re: Renee] #913947 11/04/08 03:39 PM
Mark in AZ Offline
Toyota Moderator
THanks....
Try to find a shop specializing in drivelines/driveshafts and ask them for help in confirming the carrier bearing needs replacement.
Re: Vibration on PreRunner [Re: Mark in AZ] #913948 11/04/08 09:41 PM
john_luttrell Offline
Toyota wheels are lug centric and require the wheels to be mounted to the balancing machine using the "lug adaptor". If the shop you are using is using the "cone adaptor" to mount the wheels to the balancing machine you will always have vibrations.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Vibration on PreRunner [Re: Renee] #913949 11/07/08 05:17 AM
kewlynx Offline
**ubi apis- ibi salus**
Re: Vibration on PreRunner [Re: kewlynx] #913950 11/09/08 03:53 PM
Renee Offline OP
Thanks for the article. I have not lifted my PreRunner but the carrier bearing has about 1/2" of play in it.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6350 MB (Peak: 0.7590 MB) Data Comp: Off Server Time: 2026-11-03 12:29:13 UTC
