how to swap efi for carb #913964 11/02/08 06:50 PM
Stairone Offline OP
I took an engine out o my 2wd 86 truck with carb and put it into my 4 runner and the efi is all missed up in the 4 runner and i was wonrdering if i put the intake and carb on back on the engine where would the green plug on the carb plug in
Re: how to swap efi for carb [Re: Stairone] #913965 11/02/08 09:30 PM
Scerb Offline
Just hard wire it through an ignition source. See my carb faq in my sig for a wiring diagram of that green plug. You will also need to put in a fuel pressure regulator set at 3-7psi.
Re: how to swap efi for carb [Re: Scerb] #913966 11/02/08 09:58 PM
Stairone Offline OP
i hope it works efi just driving me crazy cant figure it out
Re: how to swap efi for carb [Re: Stairone] #913967 11/03/08 12:01 AM
Scerb Offline
it will work, but I'd figure out the EFI instead. Even if you have to pay a mechanic..
Re: how to swap efi for carb [Re: Stairone] #913968 11/03/08 02:30 AM
Stairone Offline OP
I just know alot more about carbs than injection and i cant figure it out and its the only auto i have so are there down sides to a carb. mpg? power? what?
Re: how to swap efi for carb [Re: Stairone] #913969 11/03/08 02:55 AM
kewlynx Offline
No more steep hill climbing with a carb.
**ubi apis- ibi salus**
Re: how to swap efi for carb [Re: kewlynx] #913970 11/03/08 03:00 AM
Stairone Offline OP
i do a little mud but not to much offroad just wondering about the mpg mostly
Re: how to swap efi for carb [Re: Stairone] #913971 11/03/08 06:39 AM
McQ Offline
I'm an old timer and I understand that injection has many,many good points but... I have carbs in all 4 of my toys (most converted)
We race one and play(daily drivers)in three and once a spring loaded needle and seat is installed I have never had a carb let me down. I've seen injection run upside down and I can't argue with that. But if I don't have a dry sump oiling system I'd like to have my truck stop ruunning if it's upside down??
I could be wrong...
McQ
Webers and Holleys ..Old school all the way !!
Re: how to swap efi for carb [Re: McQ] #913972 11/03/08 10:10 PM
Stairone Offline OP
i have the factory carb that was on the engine when i switched over to the efi do i really need all thous vac lines i know i have to have two for vac advance but come on there must be 15 of them
Re: how to swap efi for carb [Re: Stairone] #913973 11/04/08 02:39 PM
McQ Offline
We run webers and holleys, and only use two vacuum lines. One to the distributor and one to the power brakes. Everything else gets plugged.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6363 MB (Peak: 0.7432 MB) Data Comp: Off Server Time: 2026-06-20 18:05:33 UTC
