EFI wont work #913979 11/02/08 08:18 PM
Stairone Offline OP
I have an 1986 4 runner and i have fire to the plugs and gas to the rail it wont run tyurns over and can spray gas into the efi and will run breifly have checked the maf and the tps both check out ok but the injecter wont fire truck ran fine before engine swap and now it wont
Re: EFI wont work [Re: Stairone] #913980 11/02/08 08:27 PM
4Crawler Offline
Search this forum for "+Injector +Wire +Splice". Over the last few years there are a few good threads on that common problem that prevents the injectors from firing, if that is indeed the cause of your problem.
Re: EFI wont work [Re: 4Crawler] #913981 11/02/08 09:05 PM
Stairone Offline OP
its not the splices i checked them all
Re: EFI wont work [Re: Stairone] #913982 11/02/08 09:25 PM
4Crawler Offline
Re: EFI wont work [Re: 4Crawler] #913983 11/03/08 02:27 AM
Stairone Offline OP
I have fuel to the rail no jumper needed the injecters just ont fire
Re: EFI wont work [Re: Stairone] #913984 11/03/08 03:14 AM
4Crawler Offline
Ground strap from intake runners down to the passenger side motor mount installed? Ballast resistor on passenger side fender getting power?
Re: EFI wont work [Re: 4Crawler] #913985 11/03/08 03:25 AM
Stairone Offline OP
yes to both ballest and ground
Re: EFI wont work [Re: Stairone] #913986 11/03/08 08:48 PM
4Crawler Offline
See if the injectors are getting the ground signal from the ECU, pins No10 and No20. May need to use a special test light (a.k.a. noid light) to check that.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6249 MB (Peak: 0.7221 MB) Data Comp: Off Server Time: 2026-06-22 06:11:52 UTC
