Rear Wheel bearing? #914005 11/03/08 04:34 AM
bae146 Offline OP
Anyone changed a rear wheel bearing on a gen 2 yet? If so where did you get the parts? From my surfing I gather that the rear bearings are greased and not running in gear oil. If so what a dumb idea!!! Looks like an old school Dana 44 with a pressed in collar etc...
Re: Rear Wheel bearing? [Re: bae146] #914006 11/03/08 05:56 PM
Happy Birthday Mitsulvr Offline
I've replaced mine on the first gen. I think they about the same. Wasnt to bad and I did it in the alley <img src="/forums/images/graemlins/drunk.gif" alt="" />
Eric Wegerich
89 Montero as chopped as can be. Now with 5.29's
Re: Rear Wheel bearing? [Re: Mitsulvr] #914007 11/03/08 07:55 PM
bae146 Offline OP
I am chasing a weird vibration and am not sure if it is a wheel bearing. Are the wheels on this truck located by the wheel center, or by the wheel lugs? If the wheel lugs then I am sure the tires were only balanced by using the wheel centers.
Re: Rear Wheel bearing? [Re: bae146] #914008 11/04/08 12:57 AM
Lugcentric (sp?) I believe. Non of my wheels sit on the hub ring anyways. If i recall correctly the rear hub ring is smaller than the front hub anyways.
If you jack up the axle can you move the tire and hub around? I cant explain it well but I could show you on my Sami as it just tossed the rear wheel bearing.
Eric Wegerich
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6040 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-05-29 15:45:52 UTC
