Just had the 'steering' arm/Tie rod recall done #914584 11/06/08 04:54 AM
fire4effect Offline OP
It was quite painless. It was all done in 3hrs. They even did an alignment. They also pointed out numerous things that were in need of repair which I knew about, but one I didn't. They said the wheel bearings were going bad because the noticed a lot of 'play'. What kind of 'play' are they talking about? I don't hear any of the normal whining noise generally associated with a bearing going out?
Semper Fi,
Alfred
'91 4Runner V6 4WD 400+K
'10 Scion Xb
Re: Just had the 'steering' arm/Tie rod recall done [Re: fire4effect] #914585 11/06/08 03:41 PM
grandeyota Offline
Jack up the truck and grab the wheel at the top and bottom and see if there is play. Don't grab it at the sides, that would find play in the steering parts.
Fur clog in the sausage grinder
Re: Just had the 'steering' arm/Tie rod recall done [Re: grandeyota] #914586 11/06/08 07:11 PM
Which bearing is likely bad...the hub or outer...or should I expect to change both?
Semper Fi,
Alfred
'10 Scion Xb
Re: Just had the 'steering' arm/Tie rod recall done [Re: fire4effect] #914587 11/06/08 07:36 PM
4Crawler Offline
You can usually pull the bearings out and examine the races and rollers for pitting and discoloration. Might be they just need cleaning, repacking and then the pre-load reset:
- http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml#Rebuild
Re: Just had the 'steering' arm/Tie rod recall done [Re: 4Crawler] #914588 11/07/08 02:12 AM
wsquaredodie Offline
Mine were discolored at 160k. Replaced them
trafdlo
Re: Just had the 'steering' arm/Tie rod recall done [Re: wsquaredodie] #914589 11/07/08 04:35 AM
A
Andy87 Offline
When I took my truck to the dealer to have the steering recall done, they were helpful enough to let me know of some important maintenance that needed to be done as well- they said my fuel filter really needed to be changed. Strange that they would come to that conclusion, since I had recently swapped a diesel in, and the filter was just fine...
I think they were just trying to drum up some business. Something tells me they wouldn't have had the correct filter in stock- I should've taken them up on the offer, just for the fun of it! (Not that you shouldn't pay attention to what they said... but at least keep their possible motives in mind).
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
Re: Just had the 'steering' arm/Tie rod recall done [Re: fire4effect] #914590 11/07/08 04:13 PM
Adam F Offline
The play could be something as simple as the spindle nuts being loose. Just re-torque them and it would go away.
Still a good idea to inspect and repack your wheel bearings though. Especially if it hasnt been done in years, and you find some play.
97 4R, stock, daily driver
Re: Just had the 'steering' arm/Tie rod recall done [Re: Andy87] #914591 11/07/08 06:29 PM
krb90 Offline
funny....a guy at the dealership here said they no longer replace fuel filters on these toyotas. Makes you wonder what some of these guys really know.
Re: Just had the 'steering' arm/Tie rod recall done [Re: krb90] #914592 11/07/08 07:41 PM
RatLabGuy Offline
My FSM actually has no maintanance interval or replacement info for the fuel filter <img src="/forums/images/graemlins/zombie.gif" alt="" />
When I rebuilt the motor, I did it then, just because it was nice and easy. PITA any other time.
Question Reality.
Re: Just had the 'steering' arm/Tie rod recall done [Re: RatLabGuy] #914593 11/07/08 10:02 PM
Snowtoy Offline
My Chilton's has it at 80k for fuel filter changes. I could see why the dealership would tell you they don't change them anymore, it is a PITA w/the 3.0's
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6447 MB (Peak: 0.7661 MB) Data Comp: Off Server Time: 2026-05-29 14:36:52 UTC
