My hole can't take my stud... #914610 11/06/08 06:15 AM
W
WagonMaster Offline OP
The online resource says the Honey Pot uses 12 x 1.5" studs. The wheels I'm looking at getting are 12 x 1.25".
If I'm reading right, the wheel's holes are .25" too small in diameter to fit the Honey Pot's studs. If this is so, could they be safely bored out?
Oh, and will 285/70-17's fit on a stock Raider?
Thanks
Wagon Master
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: My hole can't take my stud... [Re: WagonMaster] #914611 11/06/08 09:17 AM
DREDnot Offline
Relax...thats the thread pitch of the studs.
Stud thread diameter is 12mm wide and 1.5mm from thread to thread
The other is 12mm wide also but a finer pitch of 1.25mm between threads.
Check the actual pitch of YOUR studs so you have lugnuts that match
91 Montero LS,3.0L,auto,off road pkg.
89 Trooper S,2.6L,5 spd
07 Dodge Ram 2500 4x4,5.9L Turbodiesel,6spd
"Non Vi Sed,Arte"
Re: My hole can't take my stud... [Re: DREDnot] #914612 11/06/08 04:49 PM
W
So the 12mm stud will fit in my hole? Should I use anti-sieze?
Um, wait...
Good to know. Any idea if the tires will fit?
Re: My hole can't take my stud... [Re: WagonMaster] #914613 11/06/08 05:18 PM
V
vr4 Offline
12mm is the size of the stud. same size as the stud on the truck youre getting the wheels from. the thread pitch is different so you will not be able to use the lug nuts from the other truck. if you cant use your lug nuts youll have to find some at a parts store or tire place. the lug nuts you use have to match the wheels (shank, acorn, etc)
as for those tires....i dunno. thats pretty big. as for anti-sieze.....i am NOT a fan of the stuff. never had a problem in my 12 years of turning a wrench by not using it.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: My hole can't take my stud... [Re: vr4] #914614 11/06/08 06:41 PM
Wheel studs and nuts are dry applications, no lube or sealer.
Your tire size should clear with adequate backspacing. I'm running 33x12.5 on rims with 4" backspacing.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6065 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-06-10 07:23:01 UTC
