efi working now but it pulsates at idol #914693 11/06/08 08:27 PM
Stairone Offline OP
I got the efi to work and now it pulsates badly at idol I dont know what to do now
Re: efi working now but it pulsates at idol [Re: Stairone] #914694 11/06/08 09:07 PM
Staceman Offline
You mean that RPM's go up-n-down in 1 or 2 sec. intervals?
Re: efi working now but it pulsates at idol [Re: Staceman] #914695 11/06/08 11:55 PM
ErikB Offline
Toyota Moderator
Idle is probably set too high.
http://home.4x4wire.com/erik
Re: efi working now but it pulsates at idol [Re: ErikB] #914696 11/07/08 12:06 AM
Scerb Offline
What was wrong with your EFI?
For the idle thing, you're probably low on coolant. The coolant temp sensor will pickup air bubbles and oscillate between cold and warm idle speeds. Check that first.
Re: efi working now but it pulsates at idol [Re: Scerb] #914697 11/07/08 03:49 PM
Stairone Offline OP
The EFI the wire splices where makeing good conction but teh wire was cracked and shorting out that is why it would run then die. repaced the whole wire and it works. the pulsating stoped when i unpluged the EGR so now i dont know if i need it or not.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6038 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-05-30 00:16:23 UTC
