efi working now but it pulsates at idol
#914693
11/06/08 08:27 PM
I got the efi to work and now it pulsates badly at idol I dont know what to do now
Re: efi working now but it pulsates at idol
[Re: Stairone]
#914694
11/06/08 09:07 PM
You mean that RPM's go up-n-down in 1 or 2 sec. intervals?
[Re: Staceman]
#914695
11/06/08 11:55 PM
Toyota Moderator
Idle is probably set too high.
[Re: ErikB]
#914696
11/07/08 12:06 AM
What was wrong with your EFI?
For the idle thing, you're probably low on coolant. The coolant temp sensor will pickup air bubbles and oscillate between cold and warm idle speeds. Check that first.
[Re: Scerb]
#914697
11/07/08 03:49 PM
The EFI the wire splices where makeing good conction but teh wire was cracked and shorting out that is why it would run then die. repaced the whole wire and it works. the pulsating stoped when i unpluged the EGR so now i dont know if i need it or not.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6059 MB (Peak: 0.6700 MB) Data Comp: Off Server Time: 2026-05-30 00:17:24 UTCValid HTML 5 and Valid CSS
