Page 3 of 4 1 2 3 4
Re: Wheels ? [Re: off-roader] #914818 11/12/08 08:49 PM
W
WagonMaster Offline
NO GO - he forwarded some pic's - 4 lug on a Titan??? - those won't work (if the pic's/fit were correct).
Uh... I think Titans are the same bolt pattern. Just not sure about the hub size.
http://www.clubtitan.org/forums/showthread.php?t=34125
Bore is listed as 108mm, same with Monteros.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: Wheels ? [Re: WagonMaster] #914819 11/12/08 09:07 PM
W
WagonMaster Offline
Speaking of wheels, anyone know what wheel this is, and where I can get some?
Re: Wheels ? [Re: WagonMaster] #914820 11/13/08 12:20 AM
Pete_D Offline OP
The guy sent me some pix of the Titan wheels. Per his measurements the bore is 76.5. It looked way too small in the pictures to bother to go and check out.
Lost out on the FJ wheels - damn......
Anyone tried the TRD Toyota wheels????? Seems to be some around (realizing 2mm additional center bore needed).
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: Wheels ? [Re: Pete_D] #914821 11/13/08 04:58 AM
W
WagonMaster Offline
Update!!!
Wagon Master should never, ever post when tired. <img src="/forums/images/graemlins/sleeping.gif" alt="" />
The Titan wheels are indeed 78mm bores. All the other Nissan wheels on the list are 100mm bores.
The original list has been updated to reflect this.
I apologize for leading you astray.
Re: Wheels ? [Re: WagonMaster] #914822 11/13/08 05:25 AM
justice Offline
Those are OEM 92/93 Montero SR wheels 15x7.
Re: What OEM wheels fit a Gen1 ? [Re: Pete_D] #914823 11/17/08 09:21 PM
RaiderRascal17 Offline
I tried my dads 16 inch after market wheels with 32s from his 2005 silverado and they fit just fine (I thought that was cool same bolt pattern after 18 years). no grinding or anything.
Re: Wheels ? [Re: WagonMaster] #914824 11/17/08 09:56 PM
dadrab Offline
Keeping in mind that Mitsubishi offered "official" aftermarket wheels at several times through the years - that it to say, wheels that were ordered exclusively through Mitsu. channels, but arrived in an aftermarket box with various names on them according to who they contracted that specific style with.
That could be what you're looking at in this photo. I recall seeing that wheel before, but not often.
with awesome audio.
Re: Wheels ? [Re: WagonMaster] #914825 11/17/08 11:28 PM
KrzyDav Offline
On the talk above that Toyota wheels need to be machine out to fit,,,
I have a set of Tundra/Tacoma/Prerunner alloy wheels and they fit over my front hubs/hub ok,,,they are tight but they do fit over them.
I'm trying to get rid of them because I'd need backspacers to keep my track at least the same width. I don't want to do that. Might take the to the recycle , here they pay good for them.
Anyway,I got a "to good to be true" deal on an almost new set of BG ATs and on 15x7 alloys- $160 <img src="/forums/images/graemlins/smile.gif" alt="" />
dave h.
Re: Wheels ? [Re: KrzyDav] #914826 11/18/08 03:06 AM
justice Offline
Krzydave..can you post a pic of the tundra wheels I might be interested if they are the ones I'm thinking of.
Re: Wheels ? [Re: justice] #914827 11/18/08 03:44 AM
87Raider_TSI Offline
I'm running 16" wheels off a late model Montero Sport. They bolt up fine and I even got the Raider's rear hub covers on with only a little trimming..
They look like this:
'87 Raider SWB 2.6T/5 spd - Boxy and boosted.
'88 Conquest TSI - MPI and lots of other mods
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6423 MB (Peak: 0.7677 MB) Data Comp: Off Server Time: 2026-06-21 00:08:41 UTC
