Cleaning the top of the engine block. #914940 11/09/08 02:53 AM
Chunky Offline OP
What is the correct way to clean the top of the engine block when changing the head gasket?
'87 4Runner
Re: Cleaning the top of the engine block. [Re: Chunky] #914941 11/09/08 03:24 AM
Scerb Offline
I usually carefully use a gasket scraper and some carb cleaner or something.
Re: Cleaning the top of the engine block. [Re: Scerb] #914942 11/09/08 04:36 AM
wsquaredodie Offline
You have to be sure the bolt, water jacket and the cylinder holes do not accumulate crap from the scraping. The bolt holes are easy as compressed air will clean them out. Judicious use of tape will cover the others. When you are ready to bolt down the heads, use brakleen or similar product to clean the bolt holes. Bolt holes need to be absolutely clean. It is also a very good idea to use new bolts and to chase the bolt holes with a bottom tap before the final air blow out. The final scrape of the head and the block really works well if you use a simple single edge razor blase scraper with light pressure.
trafdlo
Re: Cleaning the top of the engine block. [Re: Chunky] #914943 11/09/08 04:42 AM
yota4runna Offline
I use the flat side of a bench grinder wheel with the paper label removed. Spray the block surface with carb cleaner, and rub back and forth with the grinder wheel. It removes all the old gasket material down to the metal, while maintaining flatness. Be sure to thoroughly clean out the head bolt holes with a tap, then carb spray, then compressed air. Many head gasket failures are due to oil or antifreeze remaining in the bottom of the bolt holes, causing the head bolts to hydro-lock and not getting tight, even with correct torque wrench reading.
Re: Cleaning the top of the engine block. [Re: yota4runna] #914944 11/09/08 04:44 PM
CJMT100 Offline
Buffer wheel with rubber pad, or I use a scraper and some gasket remover and make sure to block off all orifices.
Re: Cleaning the top of the engine block. [Re: Chunky] #914945 11/09/08 05:35 PM
Adam F Offline
For the bolt holes, use brake clean with a shop vac to suck the liquid out. Rinse and repeat.
97 4R, stock, daily driver
Re: Cleaning the top of the engine block. [Re: Adam F] #914946 11/11/08 02:34 AM
Dead on for you and 4runna. Just need to pay attention to where the crud goes. If it gets into the water jacket, maybe no prob with a good flush. If it gets into the cylinder piston-wall gap, that can be a real problem. that's why I suggested sealing both as best as possible. Then vacuum like crazy. Cleanliness is next to Godliness........
trafdlo
Re: Cleaning the top of the engine block. [Re: Chunky] #914947 11/13/08 10:33 PM
moto629 Offline
does anyone ever use a little never-seize lube on the head bolts ??? I doing a motor rebuild and using new headbolts and everything is really clean, thanks !
Re: Cleaning the top of the engine block. [Re: moto629] #914948 11/13/08 11:30 PM
RatLabGuy Offline
I've always wondered if that's a good idea. I've wondered if the never-seize will break down with the extreme heat/force in there.
My bigger concern, though, is how having it on the threads (and getting kind of squeezed around when you're threading them in) affects the torque reading when torqing down the head bolts, it probably won't be "true".
I'd bet EB has the answer...
Question Reality.
Re: Cleaning the top of the engine block. [Re: RatLabGuy] #914949 11/20/08 08:42 PM
spungo Offline
Whoa...that's gonna be a BIG NEGATORY on any creative condiments on OEM head bolts. Anti-seize is great stuff when used in the right application, and this most certainly ain't it. You don't want anything that will change the friction when torquing head bolts. Note the torque differences using ARP head studs with their lube vs. oil.
I was pulling my front hubs yesterday, though, and the tiny bit of anti-seize I opted to put on each of the infamous cone washers resulted in the easiest removal ever.
1986 Sunrader Motorhome 22RE $200
1987 4Runner 22RE (under construction) $80.77
1989 4Runner 22RE, 6" lift, 35" Dunlop mudders $420
All rescued from sitting to death, all auto, 'cuz I'm too dumb to drive a standard.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6335 MB (Peak: 0.7412 MB) Data Comp: Off Server Time: 2026-05-30 01:22:23 UTC
