need help pls on coolant leak
#914978
11/09/08 02:11 PM
hey i was wondering from all the experience here how do you tell where coolant is leaking from. How do you tell the difference between the water pump and head gasket? Oil is fine, no milky stuff, and coolant hasnt any oil in it. But it does constanly drip from somewhere around the water pump. I cant be too sure without removing the water pump. I took the timimg covers off today to try and see if i could pinpoint it, but to no avail. Coolant is leaking from somewhere at the front centre of the engine. Checked hoses and stuff, they were fine. So some help on trying to determine the likely cause of the leak. Wasnt prepared to take the timing belt off and pull the water pump out just to see. So if the water pump leaks, does it leak in that general area, or if it is the head gasket, what should i be looking out for.
Thanks guys
97 sportage, mostly stock apart from king springs front and rear, monroe shocks, k&n filter, pioneer mp3 cd, rampage 2x 10"subs and rampage amp.
Re: need help pls on coolant leak
[Re: menotthat]
#914979
11/09/08 04:30 PM
In my experience, when water pumps leak, it it usually the shaft seal. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Everet]
#914980
11/10/08 11:39 AM
if that is my problem, what signs would i see.
thanks
[Re: menotthat]
#914981
11/10/08 03:22 PM
Any leak from the waterpump will just go from alittle to alot,mostlikely its the gasget,did I spell that rite?anyway good luck <img src="/forums/images/graemlins/cyclops.gif" alt="" />
99' sportage,4"lift RSG,31" M/T Baja MTZ on DC1 rims,custom 1 3/4" body lift, one dog,one cooler,one heavy foot,maps, and the will to wheel my kia with the rest of the offroad world
[Re: victwisted]
#914982
11/11/08 10:08 AM
are you talking about the water pump gasket or head gasket?
[Re: menotthat]
#914983
11/11/08 08:04 PM
the pump is alot lower then the head. check all the hoses, if you have a lot of miles on it and the t/b and w/p have never been changed do it.
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#914984
11/12/08 02:18 PM
going to change the t/b and w/p and hope that fixes it. it has just over 176000kms and i think the belt got changed at the 100k mark. not sure about the water pump. just need to wait for the parts to arrive.
[Re: menotthat]
#914985
11/13/08 09:55 PM
Kia Moderator Emeritus
Something to check: on the exhaust manifold side of the block just below the alternator there is a steel heater hose that goes into a right angle fitting in the block just behind the water pump. This fitting has an O ring which is prone to leaking. It usually leaks ONLY when the engine is cold. Once up to operating temp the leak stops. I would check that fitting.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Axe Man]
#914986
11/14/08 01:39 PM
checked that. it wasnt leaking from there hot or cold. thanks anyways. i did hope it was something that easy.
