U Joint Clank #915323 11/10/08 08:22 PM
Tcloud Offline OP
I just replaced the U joints about a year ago and now its making this noise again. I just checked them and they are tight.
Its a 1988 Toyota 4x4
Re: U Joint Clank [Re: Tcloud] #915324 11/10/08 08:55 PM
Scerb Offline
did you check how much play the diff has?
Re: U Joint Clank [Re: Tcloud] #915325 11/14/08 01:55 AM
OOP'S Offline
Just because they are tight does not mean they are good. Did you use OEM (Toyota) U-joints or aftermarket. OEM are the best.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: U Joint Clank [Re: Tcloud] #915326 11/14/08 09:28 AM
Snowtoy Offline
Is the truck lifted, using rear blocks?. Non-stock drive angles can quicken u-joint wear. Damaging the bearings on install, or not greasing them up can/will also cause early wear.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6001 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-06-21 12:20:42 UTC
