5.0+AODE+1356BW to go in my 89. #915368 11/11/08 01:47 AM
Y
yankneck696 Offline OP
I purchased a 94 Bronco drivetrain today.
Engine was reringed & bearinged last year. AODE blew out the "diode" & will need upgrades & a rebuild at around $400 in parts & free labor from a friend. CV driveshafts front & rear.
I'll probably do a 2" body lift (if needed) & 4door springs for rear & crank & UCA swap for the front with 33's, 34's or 35's to keep the RPM's decent.
It'll probably be a couple months before I can start, but will power through it in a week of vacation.
I'll already have the old drivetrain out & wiring combined before I start.
I'll measure & take alot of pics of it & keep a full record of the difficulties I encounter.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: 5.0+AODE+1356BW to go in my 89. [Re: yankneck696] #915369 11/11/08 01:56 AM
justice Offline
Sounds good cant wait to see it!
Re: 5.0+AODE+1356BW to go in my 89. [Re: yankneck696] #915370 11/11/08 01:59 AM
lordtrunks Offline
you may have problems fitting the borg warner 1356 into your truck as it maybe too big you may want to go T shift dana 20 or another t\case.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 5.0+AODE+1356BW to go in my 89. [Re: yankneck696] #915371 11/11/08 02:10 AM
sewerrat Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Will the T-case fit inside the frame? In the early Bronco world, there is a problem with hitting the frame. Have seen some pix of heavy frame notching <img src="/forums/images/graemlins/shiner.gif" alt="" />
IIRC the NP205 may be a bolt-up for the AODE, and is small enough to fit the old Broncos. The 205's low range is not that low, but they are tough/cheap. Stay away from the Dana 20 box, the Bronco folks need them all!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Too many snapped output shafts.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> Bob
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: 5.0+AODE+1356BW to go in my 89. [Re: sewerrat] #915372 11/11/08 12:21 PM
Y
I have the 205 on my mind, if there are any fitment problems. I would like to do my best to not have a body lift.
Ed
Re: 5.0+AODE+1356BW to go in my 89. [Re: yankneck696] #915373 11/11/08 01:36 PM
lordtrunks Offline
Advanced makes a 32 spline output for the dana 20 and the T shift 20's have a better low range than the 205 does,
Re: 5.0+AODE+1356BW to go in my 89. [Re: lordtrunks] #915374 11/12/08 01:02 AM
Y
Would you know if I can mount up the CV flange to the D20? I guess I'll check what Advanced has on their site.
Thanks...
Ed
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6158 MB (Peak: 0.6945 MB) Data Comp: Off Server Time: 2026-07-17 01:12:02 UTC
