Weber 22R Carb Tech #915395 11/11/08 05:03 AM
kewlynx Offline OP
Yepper. For you **22R** Weber-heads out there. Here's your archival thread, or better yet, write an article for the 4x4portal!!
http://www.4x4wire.com/index.php?op...w=section&id=3&Itemid=74
**ubi apis- ibi salus**
Re: Weber carb tech [Re: kewlynx] #915396 11/11/08 05:06 AM
yodta Offline
nice!
I'll see if I can get my old photos together in my "spare" time smile
msg - '87 xtracab
Re: Weber 22R Carb Tech [Re: yodta] #915397 11/11/08 06:46 AM
kewlynx Offline OP
Ver' cool; we've been needing this for awhile. Scerb's website for Aisins is pretty schweet. Miss Josh around here...HEY JOSH!!!
Re: Weber 22R Carb Tech [Re: kewlynx] #915398 02/04/09 01:47 AM
ArbitraryNotion Offline
I miss stopping around. What kind of info are you looking for? <img src="/forums/images/graemlins/cheers.gif" alt="" />
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Weber 22R Carb Tech [Re: ArbitraryNotion] #915399 02/04/09 02:09 AM
kewlynx Offline OP
Anything you want to contribute- there's enough Weber Q.s around; would be nice to have a repository or a tech article (the boss might send ya a shirt)
Great to see you're still around Josh!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Weber 22R Carb Tech [Re: kewlynx] #915400 09/13/09 03:20 AM
gueroblanco Offline
maybe I should post any questions in here...
'95 runner 3vze/r150f
Re: Weber 22R Carb Tech [Re: gueroblanco] #915401 10/04/09 10:45 PM
I
idhank Offline
Is there anybody out there that can give me an idea of what I can do to my Weber carburetor to get it pass emission here in Idaho what I have is an 1980 4 x 4 pickup with a 1982 22 R motor and a Weber 32/36 carburetor that doesn't want to pass emission at idle for hydro carbons. Any help would be greatly appreciated.
Thanks Idhank
Re: Weber 22R Carb Tech [Re: idhank] #915402 10/05/09 11:04 AM
Ralph Offline
Mix 1 part gas to 2 parts Alcohol.
This works in California.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Weber 22R Carb Tech [Re: idhank] #915403 02/06/10 11:00 AM
XJCreeper Offline
Thanks Idhank
I don't have a Weber, but the process should be similar to the FSM one I've been using with the stock carb:
Get a timing light, pull off and plug the vacuum advance on the distrubutor off, and check and dial in the timing. Timing is usually been the root off my not passign emissions.
Next get a tach on the motor and dial in the idle and fuel mixture. This can be accomplished by uping the idle and leaning out the mixture till ya hear the valves get a bit noisy. Then checking the tach slowly making it richer until the idle doesn't go up anymore. Then set the idle and head to the smog shop.
I go through this with my carb'd motor every so often through the smog check. My carb must be getting it screws loose or something after a while <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Weber 22R Carb Tech [Re: kewlynx] #915404 10/31/11 06:37 PM
Here's a quick Weber gem:
Ditch the stock fuel pump. When I converted to a Carter 4070 electric fuel pump the truck ran so much better. I've now been using one for several years and it was well worth the $100. I bolted my to the passenger side of the cab right next to the fuel lines so I could just add it inline. LCEngineering sells a fuel pump blockoff plate so the pump can just go away.
If I had to do it again I would have installed it near the fuel filter so I didn't have to listen to the pump because it is loud! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6377 MB (Peak: 0.7621 MB) Data Comp: Off Server Time: 2026-10-21 19:37:23 UTC
