22re Cam Gear Question #915720 11/14/08 03:18 AM
mental Offline OP
Just finishing a full rebuild on an '87 22re and when installing the cam gear, found that it wouldn't sit flat on cam's shoulder when installed with gear marks facing forward. When I flipped the gear it fit perfectly. Obviously the bore of the gear is somewhat out of round on one side. As I purchased the timing set over a year ago and am only now getting around to the project I doubt the parts store will help me out. Can I run this gear either way, the gear offset seems even both ways. Your help is greatly appreciated, I'd love to get this finally finished...
Re: 22re Cam Gear Question [Re: mental] #915721 11/15/08 06:59 PM
mental Offline OP
Anyone? I'll need to order a new cam gear if this can't be flipped, someone must have some input, or is it that obvious that I should just grab a new gear?
Re: 22re Cam Gear Question [Re: mental] #915722 11/16/08 02:59 AM
engnbldr Offline
>>>*I just spotted this one. A quick look at the timing of the teeth will show you that it can't be reversed and run properly..
Best to replace any defective part. The supplier should replace it for you if it is defective and never been run...*EB
*Beats the he** outa me!....*LOL**...
Re: 22re Cam Gear Question [Re: engnbldr] #915723 11/16/08 05:51 PM
mental Offline OP
Thanks Ted. You rule. I'll order a new one this morning.
PHP: 7.4.33 Page Time: 0.058s Queries: 15 (0.055s) Memory: 0.6035 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-11-20 00:44:32 UTC
