shocks #915793 11/14/08 03:49 PM
O
odey Offline OP
will f150 shocks fit the rear of 99 sportage also will tj coil spring spacers 2 fit
99 kia sportage 2 door tj coil spring rear spacers in front 31x10.5 sidewider tires cat exaust in the process of making a snorkel
Re: shocks [Re: odey] #915794 11/14/08 07:55 PM
logansportage Offline
What year of F150 are you thinking?
The TJ springs are a smaller diameter than the stock Sportage springs, so the coil spacers are also smaller in diameter. They will fit, but the stock springs will not fit into the spacers and will pop out. If you have the TJ springs installed already and try to fit spacers too, you will run out of room on your breaklines and other things. Not a good idea.
Re: shocks [Re: logansportage] #915795 11/14/08 08:47 PM
O
odey Offline OP
i was thinking may be a 87 shocks would fit the 99 sportage but this was just a thought. i was told 98 rav 4 shocks will fit but the are expensive. I plan on lifting my kia i have already put 31x10.5 on it and i am tired of it draging the back fenders
99sportage 2 door soft top 31x10.5 hope to do a suspension lift when i find some tj springs
Re: shocks [Re: odey] #915796 11/14/08 08:54 PM
Everet Offline
$21.99 each expensive???
Try AutoZone
Part Number:61651 for rear shocks.
(They are working fine on mine.)
How much lift are you wanting in the rear?
Kia rear springs are prone to sagging and breaking so I wouldn't invest in any spring spacers.
Re: shocks [Re: Everet] #915797 11/15/08 04:37 AM
P
phewson Offline
does anyone run 35's under their Kia? I just bought a 99 4 door. I would like to run 35's but am having trouble finding gear sets for the diffs
Re: shocks [Re: phewson] #915798 11/15/08 01:15 PM
V
victwisted Offline
you will never get 35" tires under your sport with the IFS still in it and if you ever do find better gears let us know,check this site better for all the info you are looking for,its all here,there are threads on it all,have fun>>>> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
99' sportage,4"lift RSG,31" M/T Baja MTZ on DC1 rims,custom 1 3/4" body lift, one dog,one cooler,one heavy foot,maps, and the will to wheel my kia with the rest of the offroad world
Re: shocks [Re: Everet] #915799 11/15/08 07:17 PM
O
odey Offline OP
i would like about 3 inches lift and thanks for the price and part number on shocks i will pick up a set. do you know were i could get a used set of oem tj rear coil springs.
were did you get upyourkia spacers for front
Re: shocks [Re: victwisted] #915800 11/15/08 09:17 PM
P
phewson Offline
thanks for the reply, I was planning on making a drop bracket for the front diff, like my toyota and chevy have. in order to achive the amount of lift that would be needed.
without the bumpers and some minor trimming of the lower fenders(where the piece is below the door) I was thinking that I would only need a 6 to 8 inch lift. but without available gears, there would be no point.
<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: shocks [Re: odey] #915801 11/15/08 09:22 PM
Everet Offline
PM me about Lift Kit and check out: <a href="www.upyourkia.com" target="_blank">KIA LIFT KITS</a>
Also, the hole in the grommet of the RAV4 shock is larger, so what I did was push out the new one, and replace it with the old ones from the shocks taken off.
Everet
Re: shocks [Re: odey] #915802 11/16/08 12:44 AM
homerdog Offline
I'd check on ebay for oem tj shocks, that's where I got mine. Look for 106's
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6390 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-06-07 09:12:11 UTC
