Idle/hesitation problems @ idle through 2000rpms....just started last night??? #915906 11/15/08 05:24 PM
DJN Offline OP
So I started my truck last night and could tell it wasn't running right. At idle I can hear it miss and run really rough. When I hit the gas it hesistates pretty bad up through about 1500rpms. Under load from take off I can barely get it to go until I get over 2000rpms. It's a 2000 Taco, 180K,3.4, 5spd...never had any major engine work done. MAF? Ingition? Fuel filter?
thought I'd see if these have any typical problems like this
Thanks for your help!!!
Re: Idle/hesitation problems @ idle through 2000rpms....just started last night??? [Re: DJN] #915907 11/16/08 06:14 PM
john_luttrell Offline
Need to check for codes in the computer for a start; is the trouble light on? Was it on when it was acting up? It sounds like an ignition miss to me; check all the plugs and wires. When was it tuned up last?
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Idle/hesitation problems @ idle through 2000rpms....just started last night??? [Re: john_luttrell] #915908 11/16/08 07:19 PM
DJN Offline OP
the check engine light has not come on at all since the problem started. Last tune up was 40K ago (guessing). I don't have a manual to check codes so if you could give a heads up that would really help!
Thanks much?
Re: Idle/hesitation problems @ idle through 2000rpms....just started last night??? [Re: DJN] #915909 11/17/08 03:14 AM
You will need an OBDII code reader, or if it will drive, take it to autozone or another parts place that will read your trouble codes for you. Here is a link to your factory service manual; it has all the trouble shooting proceedures you will need.
2000 tacoma service manual
John Luttrell
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6028 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-05-29 16:03:26 UTC
