89 3.0 Raider needs ECU and some others
#916122
11/16/08 07:50 PM
I have an 89 3.0 AT Raider with the gray interior. I need an ECU and the connector that attaches to the power unit. I'm also looking for the piece that fits around the shift selector as mine has the tabs broken. Ialso need the storage bin thing that fits in the radio console. I apologize for not knowing the proper names for some of these items.
Re: 89 3.0 Raider needs ECU and some others
[Re: jrowe]
#916123
11/17/08 04:30 AM
I have the storage bin.
Can you please describe the other piece near your shift selector in greater detail? Are you woring on an automatic or stick Raider?
I do not have the ECU parts, but there has been an 89 in a nearby yard. If it's still there, I'll grab the parts you need.
Russell
[Re: rxinhed]
#916124
11/18/08 07:12 AM
I am working on an Automatic. The piece I'm looking for is the one that has P,R,N,D etc on it. It fits around the shifter. There are two tabs on the front and rear of it and mine are broken so it is loose. If you can get your hands on an ECU I would appreciate it. Thanks, Joe
[Re: jrowe]
#916125
11/18/08 05:32 PM
If Rx cant get the ECU for you. There was one in a 89 I was just pulling stuff off of this weekend. I could go back and grab it if needed.
Z
Do you think the average stormtrooper knows how to install a toilet main? All they know is killing and white uniforms.
87 Raider TSI 84 K5, 350/700R4,36" TSLs, spooled fr/rr 74 VW Bug- volksrod project 68 VW Fastback, 2L T4 powered
[Re: jrowe]
#916126
11/18/08 05:33 PM
OK, I'll check on all the other parts later today.
[Re: CwnAnwyn]
#916127
12/02/08 08:30 PM
While you guys are checking I need the bolt that holds the harmonic balancer (crank pulley)on for my 89 Montero 3.0. And if the fan clutch is good....?
[Re: bearingman]
#916128
12/02/08 09:42 PM
You don't want that bolt. Go to the Dodge dealer and get P/N's 1101A022 Bolt & MR994412 Washer. Those are the most current iterations of the updated bolt and washer.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6160 MB (Peak: 0.6933 MB) Data Comp: Off Server Time: 2026-06-07 09:07:23 UTCValid HTML 5 and Valid CSS
