Page 3 of 4 1 2 3 4
Re: SR front end swap? [Re: StockRaider] #916393 11/21/08 02:36 AM
Chris_J Offline
also a high pinion design with the same ratios. I think this might be more of a direct bolt in.
What the point of a high pinion with IFS? I know the gen1s have a skid running the length of the front shaft. I could see it with a solid axle, with IFS its all fixed doesn't move.
Re: SR front end swap? [Re: Chris_J] #916394 11/21/08 12:07 PM
High pinion is used for full time operation through the gears. It is so the gears drive on the proper face whereas a low pinion drives on the reverse face. It is done for longevity not clearance.
Re: SR front end swap? [Re: OldColt] #916395 11/24/08 04:08 PM
L
Lee N Offline
I was thinking of the 4.90 gears available more than anything, but the HP is a bit stronger than a LP design due to running on the drive side of the gear instead of the coast side.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: SR front end swap? [Re: Lee N] #916396 11/25/08 12:46 AM
sparkem Offline
How many people have broken their front diff?
Re: SR front end swap? [Re: sparkem] #916397 11/25/08 01:11 AM
V
vr4 Offline
friend broke an 06 F350 powerstroke front diff with 35s.
granted he was in mud..... <img src="/forums/images/graemlins/lol.gif" alt="" />
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: SR front end swap? [Re: vr4] #916398 11/25/08 02:28 AM
Chris_J Offline
06 F350 powerjoke
Fixed
Should of bought one of the below.
Re: SR front end swap? [Re: Chris_J] #916399 11/25/08 03:31 AM
sparkem Offline
Talking about on a Montero.
Re: SR front end swap? [Re: sparkem] #916400 11/25/08 06:30 AM
Chris_J Offline
Talking about that sparkey.
Re: SR front end swap? [Re: Chris_J] #916401 11/25/08 08:12 AM
LandRaider Offline
I broke my IFS in my truck.
Twisted the passenger side axle stub off of the CV.
Took 33X13.50 Swampers, and a 4.3, AND getting on it hard to do it.
Re: SR front end swap? [Re: LandRaider] #916402 11/25/08 07:20 PM
hazy_daze Offline
So, to clarify, there are weaker components that will break before the front diff, correct?
Oh yeah, this is referring to a Montero...
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6452 MB (Peak: 0.7690 MB) Data Comp: Off Server Time: 2026-05-26 04:58:28 UTC
