Montero gen 1 idler arm ???? #916438 11/18/08 04:50 AM
fleetbob1 Offline OP
why does mine wear out every 6 months -------is there an upgrade or modification to help???
Can i use a Gen 11 arm ?
1990 Montero LWB V6 5-SP Locked Rear/33/12.50 Kumho KL-71 Mud Terrains/3" body lift,bars/springs/poly/shocks/custom skids/lots of lights/snorkle/etc......
Re: Montero gen 1 idler arm ???? [Re: fleetbob1] #916439 11/18/08 05:43 AM
TRW bushing kit # 12709 ???
Re: Montero gen 1 idler arm ???? [Re: fleetbob1] #916440 11/18/08 05:04 PM
justice Offline
Yes you can use a gen 2 arm. Look up the a post from the username dirtdriver. Fattony also did the swap.
Re: Montero gen 1 idler arm ???? [Re: justice] #916441 11/19/08 03:25 AM
You get a whole 6 months? You're doing good. It should be on the 6000 mile service list to replace the bushings. Note the gen2 idler arm is tougher, but not rebuildable. There was some talk of machining tougher bushings. I also seem to remember somebody who used another steering box on the pside, since their pitmann shaft location is much more robust. I don't know if they used a rhd box, or if a JY lhd stering box will fit (minus the steering wheel shaft of course in both cases...)
Re: Montero gen 1 idler arm ???? [Re: fleetbob1] #916442 11/19/08 04:20 AM
Kevin C Offline
I have found that the OEM factory bushings seem to last a bit longer than the aftermarket parts.
Kevin
Re: Montero gen 1 idler arm ???? [Re: Kevin C] #916443 11/19/08 05:46 AM
I just get a new one every 6 months from my local auto parts store, a/c delco makes it and it has a 12/12 warranty.
they just keep replacing it for free.....................
Re: Montero gen 1 idler arm ???? [Re: Kevin C] #916444 11/19/08 10:26 PM
Nitteberg Offline
Here is some picture of the steering box idler arm.
The box is witout power steering and some is cut off and blended off, the arm are turned 180 degrees.
web page
http://nitteberg.com
-83 Pajero SWB Soft Top 2,3TD
35x14,5x15 PitBull Rocker
Bodylift, LSD, PTO-winch, Intercooler, 2.85 gear's
Gen2 upper a-arms, flipped and raised ball
Re: Montero gen 1 idler arm ???? [Re: Nitteberg] #916445 11/19/08 10:40 PM
justice Offline
*EDIT* posted in wrong thread.. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Montero gen 1 idler arm ???? [Re: justice] #916446 11/19/08 11:11 PM
Happy Birthday Chris_J Offline
I killed one in 2 days at Uwharrie National Forest.
Re: Montero gen 1 idler arm ???? [Re: Chris_J] #916447 11/20/08 04:48 AM
FatTony Offline
Gen 2 arm bolts on with very little or no modification. (I cut off the extra mounting tab, which wasn't really necessary) Seems to be much better than the Gen 1 arm, took a whole summer of me beating on it (and I do mean beating) and it's still tight as the day I put it on. Check out this thread for some pics of mine.
88 Raider sas, doubler, boggers
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6335 MB (Peak: 0.7407 MB) Data Comp: Off Server Time: 2026-06-21 19:04:25 UTC
