differential
#916547
11/18/08 11:58 PM
trying to find out a little about what would be my best bet on changing gear ratio ring/pinion or 3rd member on my 1997 t-100 3.4 4x4 dont even know what i have now but i do have all the # off my drivers door jam you guys/girls seem to be very savy on all subjects with the t-100 so thanks in advance for any help you may have for me <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: differential
[Re: pongoboy]
#916548
11/19/08 02:53 AM
Well if its 4wd you most likely have 4.10 or 4.30 gears
This is right in the FAQ:
AXLE- Gear ratios Axle code found on door jamb A10A = 4.10 A11A = 4.30 4.10's usually came in manual transmission 4x4 trucks, 4.30's in auto transmission 4x4 trucks.
Re: differential
[Re: CJMT100]
#916549
11/19/08 04:24 AM
well i have the a11 code i am going to try to change the gear ratio to a taller gear because i am pulling a 6000 lb trailor and want to give my old truck a break it has 118000 miles on it but all of my towing is on flat ground i have always have fords i do belive that the t-100 is a lot better truck but want a little more power with out haveing to run so hard so i would like to have your ideas on gear ratio change and also thank you for your response <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: differential
[Re: pongoboy]
#916550
11/19/08 04:28 AM
6,000lbs is over the weight rating of the truck, its only rated to tow about 5,000lbs. I would make sure you have a trans cooler, and overdrive off..
Re: differential
[Re: CJMT100]
#916551
11/20/08 11:02 AM
thanks but i do have a trans cooler and a oil cooler i was asking about gear ratio and the differnce it might make <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: differential
[Re: pongoboy]
#916552
11/20/08 03:11 PM
WHat I am saying is it wont make much difference if the truck itself is only designed to tow a max load of 5,000lbs. It will tow it, but boy it wont like it at all.
Good luck with it if you try..
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6090 MB (Peak: 0.6782 MB) Data Comp: Off Server Time: 2026-11-03 13:35:58 UTCValid HTML 5 and Valid CSS
