Re: 1989 raider / montero wont start need help please [Re: Toe] #916829 11/22/08 12:03 AM
grass13 Offline
if it cranks (which it sounds like it does) and is getting fuel (sounds like it is) that leaves fire. mix in a tune up and check your connections to the dizzy and ecu. while your at the ecu see if it smells fishy.
btw, since its a manual... try making it start, cant hurt.
Re: 1989 raider / montero wont start need help please [Re: Toe] #916830 11/22/08 09:43 AM
PatrickS Offline
Ok last post for now sorry. It has to be somthing simple i think but and ideas anyone has would be awsome. Now i had a friend pull me from my work place were the truck died back to my place and in the process for the hell of it i tried jump starting it (oh yeah its manual im an idiot and leave out details ha ) and in the process it started but died soon after - and i did give it gas but died even quicker. So anymore suggestions would be awsome and thank you and i hope some of you get a good use out of that manual , youll never need another and its accurate , and i guess the Pajero (RAider) is big in russia thats what the pdf files are off of
Mine would fire off, run for a short period and then die. After waiting 1/2 an hour the same and so on. Showed spark most of the time. In the end it was the optical sensor in the dizzy.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: 1989 raider / montero wont start need help please [Re: PatrickS] #916831 11/23/08 02:04 AM
Toe Offline OP
Good news i did get it started finally . it was the optical sensor i believe , the thing inside the distributor . so i thank everyone for there time. And also if you own a raider download that manual i put the link up for it in one of my eairlier posts that i found it has every point of the raider/montero/pajero and its in english even though its from a russian site. and thanks again for every ones help . ad the lc filter was shot so i bypassed it and then it started .Also if someone needs a parts list for the raider let me know ill email you the files i have
Re: 1989 raider / montero wont start need help please [Re: Toe] #916832 11/24/08 09:55 PM
Tach may not last long without lc filter. I'd find a good one and put it on. Did lc filter go bad as short to ground? That alone will kill the spark. Otherwise, I think it would not have an effect on spark, just on tach operation.
Re: 1989 raider / montero wont start need help please [Re: Toe] #916833 11/27/08 10:42 AM
PatrickS Offline
I am glad you found it so quick. It took me a couple of months and a lot of help from the Forum before I found it was the optical sensor. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6122 MB (Peak: 0.6931 MB) Data Comp: Off Server Time: 2026-06-07 06:03:14 UTC
