rear locker questions
#916872
11/21/08 11:10 AM
hey i just got a 92 pajero exceed 3L it has the rear locker in it but here is the question when i turn on the key the locker light turns on but i can not get it to light the locker light any other times is there a switch or anything i have a R/D LOCK button but it doesnt turn on the light and i dont hear the rear door lock eather so what do i do hope someone can help thanks
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED 1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW CURRENTLY LOCATED IN JAPAN
Re: rear locker questions
[Re: drtydzl]
#916873
11/21/08 12:04 PM
As delivered from the factory you need to have the center diff locked for the rear to be engaged.
[Re: OldColt]
#916874
11/21/08 12:14 PM
<<As delivered from the factory you need to have the center diff locked for the rear to be engaged>>
You surely can bypass the transfer case switch to get it to operate.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity. "How can I break it better?" 89 Raider 3.0 w/ 31's for now
[Re: yankneck696]
#916875
11/21/08 12:47 PM
so i put it into lowlock and then hit the R/D lock button once the center diff lock light stays light this is all new to me my last pajeros were gen 1 trucks thanks for the help
[Re: drtydzl]
#916876
11/21/08 01:52 PM
HiLoc will do it too, just not 4Hi (AWD).
