a little upset, she's rusting #916901 11/21/08 06:34 PM
91monterov6 Offline OP
i live in the salt capitol of the world ( wv oddly enough) and my frame is rusting bad, whats the easiest way to fix it, repair it or replace the whole chassis?
Re: a little upset, she's rusting [Re: 91monterov6] #916902 11/21/08 07:49 PM
Mad_Scientist Offline
I'm in the same boat <img src="/forums/images/graemlins/frown.gif" alt="" /> Some good ideas here
Re: a little upset, she's rusting [Re: 91monterov6] #916903 11/21/08 07:49 PM
I'm about to have a nice chassis you could take, with Cali title too. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: a little upset, she's rusting [Re: rxinhed] #916904 11/22/08 12:41 AM
KrzyDav Offline
Well worth the shipping on his frame if you wanna keep with the Montero. I think Ky and PA may have you beat on being salt capitol . Ky is mainly from stupidity and inbreeding.
Mines like 20 year old and hasn't form a flake of rust since I left KY.
Lots of rust free stuff here. Folk back there sould get ahode of me to find small suff , I'm a junk yard dog.
dave h.
Re: a little upset, she's rusting [Re: KrzyDav] #916905 11/22/08 06:23 AM
im just trying to figure out my options, im what would be considered in poverty lol, i make less than 10k a year, so in terms of parts and labor im kind of screwed.
this is my baby, and i dont want to have to get rid of her.
what would average price for a non rusted chassis run?
and about what would i be looking at in terms of getting engine/trans swapped over?
Re: a little upset, she's rusting [Re: 91monterov6] #916906 11/23/08 12:41 AM
the lack of replies kinda scares me, guess im looking at an expensive fix eh?
im going to try and find me another monty to swap chassis with. whats the easiest way to remove the cab/body from the chassis?
Re: a little upset, she's rusting [Re: 91monterov6] #916907 11/23/08 12:59 AM
KrzyDav Offline
This would be best a do it yourselfer or find a shadetree mechanic to help. Hope you have other transportation 'cause this will take awhile.
Maybe you could have some braces welded on .
Removal involves a forlift or overhead which to swap bodies.
You have to disconect fuel lines , brake lines , unplug wiring harnesses ,,, etc. etc. ,,,a cherry picker to drop the engine in ,,transmission jack ,,,, alot of stuff,,,good luck,,,I hate rust...
dave h.
Re: a little upset, she's rusting [Re: KrzyDav] #916908 11/23/08 01:26 AM
i checked it out, its only really bad one the drivers side, and it appears that it was a bad weld that rusted out.
i may just cut grind and have someone weld a re inforcement onto it...
ill post pics ASAP
Re: a little upset, she's rusting [Re: 91monterov6] #916909 11/23/08 02:04 AM
The lack of replies is not a bad thing, necessarily. The program you're on to fix a bad chassis is either replacement or extensive fabrication, that's all. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: a little upset, she's rusting [Re: 91monterov6] #916910 11/26/08 05:43 AM
Y
yobeatz Offline
i have a 1990 with two holes in it but i got it welded up with 3/16ths steel then undercoated the whole thing. It seems to hold up well but i might get the whole frame reinforced in a year or so
1990 Montero 4 door-
-5spd
-3.0 v6
-101,000 km!
-29" Bf goodrich allterains(want to upgrade)
-hella 500's
-cobra cb radio
-whatevver else
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6351 MB (Peak: 0.7432 MB) Data Comp: Off Server Time: 2026-05-29 22:23:01 UTC
