Sunroof seal #917486 11/25/08 05:54 AM
kela Offline OP
Any one source and/or replace the rubber sunroof seal for a Gen I LWB? Mine's deteriorated pretty badly, need to replace it.
'90 Gen 1 Montero LWB (Original owner, daily driven x 32 yrs and counting)
400k+ miles & still going strong !!!
Re: Sunroof seal [Re: kela] #917487 11/25/08 05:13 PM
Have you tried the dealer? I bought a windshield gasket for mine just a couple of weeks ago. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Sunroof seal [Re: off-roader] #917488 11/26/08 12:35 AM
kela Offline OP
Called local Mitsu dealer...Special order item, approx $150. Does any one have first hand experience replacing the sunroof seal on their Gen I that can share tips/suggestions?
Re: Sunroof seal [Re: kela] #917489 11/27/08 01:22 PM
Steve Nichols Offline
Kela
If its the same as the MkII, I have a useable one in my garage at home, replaced the sunroof bacause of rust.
Yours for the price of P&P (I'm in the UK <img src="/forums/images/graemlins/smile.gif" alt="" /> )
SteveN
Shogun (Pajero/Montero) 3.0L V6 12valve LWB Auto 1993
142k miles.
Dual Bouncy Seats
Totally stock
c/w Diff lock
now sold
Re: Sunroof seal [Re: Steve Nichols] #917490 11/27/08 10:45 PM
kela Offline OP
SteveN,
Thanks for the offer !!! Let me verify that the size of the large sunroof is the same between Gen I & Gen II LWB, then I'll get back to you. Hopefully the rubber seal will be interchangeable between the years.
Any tips/suggestions on R&R of the sunroof/seal?
Thanks,
Kela
Re: Sunroof seal [Re: kela] #917491 11/28/08 03:37 AM
Sunroof is same.
Re: Sunroof seal [Re: kela] #917492 11/28/08 01:11 PM
I'll try & get P&P price for you anyway, if the sunroof is the same then have you considered a replacement from a newer truck from a pick-n-pull?? The complete glass & seal <img src="/forums/images/graemlins/wink.gif" alt="" />
Removal of the sunroof is easy, pull back the blind remove the 4 plastic covers & the 2 nuts under each cover. Get a freind to help lift it out.
I'll try & post some pics, but my home PC is running in 'SAFE MODE' only f*#;%$ <img src="/forums/images/graemlins/scared.gif" alt="" />
SteveN
142k miles.
Dual Bouncy Seats
Totally stock
c/w Diff lock
now sold
Re: Sunroof seal [Re: Steve Nichols] #917493 11/28/08 04:14 PM
kela Offline OP
Hi Steve,
PM sent. Pics of the R&R of your sunroof, would be very much appreciated !!!
Just needed the rubber seal, as the glass is in good shape. But, if a local yard has both glass/rubber for a good price, then that might be something to consider.
Lurked on this board for many years, reading all the tech & service posts. As all Gen I's are getting a little bit long in the tooth, would be nice to see some articles, input from people who have done body work + body 'maintenance/repair/replace' on their beloved Gen I.
Thanks again,
kela
Re: Sunroof seal [Re: kela] #917494 11/29/08 01:57 PM
P
pcc Offline
I can't on a GenI but can on my GenII. I had to replace mine due to rust on the seal lip. The design is poor as it traps water/salt in the lip. I had to wire brush, sand and apply rust converter and primer/paint before replacing the seal. Use silicone to glue the seal down and have some spring clamps ready to hold it while the silicone cures. Pay particular attention to gluing the two ends together. I also found that I needed to re-glue the inner roof header in spots. As a warning to others, if you see any lifting of the seal on the outside chances are it is rust and should be looked at asap.
Re: Sunroof seal [Re: pcc] #917495 11/29/08 07:24 PM
kela Offline OP
pcc, thanks for the heads up !
No rust around my sunroof or seal, as far as I can tell. The rubber seal though is another story, deteriorated badly, need to replace. ~ 20 y.o. rubber just about at it's life's end !!! All Gen I owner's doing routine maintenance on their rigs: take a look at all of your rubber (i.e. hoses, belts, bushings, window seals/gaskets, etc., etc.).
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6368 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-10-22 14:52:44 UTC
