Compatible Engines for Gen II
#917540
11/25/08 09:53 PM
Sadly, it seems as if my Guntero has a substantial oil leak. After much dripped oil and a professional diagnosis, it has been determined that the valve seals are gone as well as the gaskets. After 275k + lovely miles, i beleive its time (and have been advised) to do an engine swap.
Which engines are perfectly compatible with my 1995 LS? And what would be the best of these to drop into my Guntero?
Thanks
Guntero (died in battle) 1995 Montero LS - Matte Black 265/75R16 BFG All-Terrains
Guntero (current) 2001 Montero Limited - Gold OME HD Lift 285/75R16 BFG All-Terrains
Re: Compatible Engines for Gen II
[Re: Guntero]
#917541
11/26/08 06:44 AM
Why not just rebuild the one you have, or get another Monty 3.0 24V? Nothing is "perfectly compatible," though there are other possibilities.
Start with a search on this one, as it comes up on a quarterly basis. Especially look at posts by FrankR and OldColt.
[Re: Guntero]
#917542
11/26/08 07:31 AM
Which engines are perfectly compatible with my 1995 LS? Thanks
24V SOHC 6G72
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#917543
11/26/08 05:30 PM
But doesn't "perfectly compatuble" have to be defined in terms of needs? As in, Diamante engine is not the exact same as a Montero. It can go in, and very well might be worth having in. But it depends on the needs.
Similarly, some variations could need some form of "fitment" to make them work. Maybe nothing much, but not necesarily plug-and-play like a Montero engine.
Disclaimer: This is all based on my memory of past threads, and not on any factual first hand knowledge. <img src="/forums/images/graemlins/lol.gif" alt="" />
