Scan gauge 2? #917723 11/27/08 07:18 AM
WunBigTacoma Offline OP
will the scan gauge 2 fit a 95.5 tacoma i have noticed it said 96 and newer? thax
Matt weaver
95,5 xtra-cab 5 spd 3.4
3.5 fabtech,w/diff drop 35x12.50,removed 3in body now running 285-75x16 on factorys,
hella lights,gauge pod,and gauges
tb spacer,intake k%n filter,flowmaster
Re: Scan gauge 2? [Re: WunBigTacoma] #917724 11/27/08 06:17 PM
humanoid Offline
It might, if you look under the dash right above the right knee there should be an OBDII port which should look something like this:
Re: Scan gauge 2? [Re: humanoid] #917725 11/28/08 06:39 PM
G
Greg_Canada Offline
yes it will work, because it's OBDII just like all other 3.4's/2.7's.
I have one on my 99 and love it.
89 4Runner
Re: Scan gauge 2? [Re: Greg_Canada] #917726 11/28/08 08:13 PM
where did you get yours from?and how much was yours i have seen them up too $169? what all gauges does it have on it. thax
Matt weaver
Re: Scan gauge 2? [Re: WunBigTacoma] #917727 11/29/08 10:11 AM
humanoid Offline
Have you been to scangauge.com yet?
Re: Scan gauge 2? [Re: humanoid] #917728 12/02/08 04:25 PM
E
EnolaGaia Offline
You should contact ScanGauge to make sure. OBDII compliance was mandated starting with vehicles built and sold on or after 1 January 1996.
According to the compliance listing at:
http://www.obdii.com/connector.html
... pre-1996 model year Tacomas were not 100% OBDII compliant. This doesn't necessarily rule out a ScanGauge working on your 1995.5 Taco, but it does indicate some more research is required ...
Of _course_ I know the difference... I don't want you to kiss a hole in the ground.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6099 MB (Peak: 0.6791 MB) Data Comp: Off Server Time: 2026-10-22 07:41:01 UTC
