can someone help me out with wiring?
#917729
11/27/08 03:44 PM
swapped a 2.2 C223T into a toyota, now when it comes down to starting the thing, it wont.
so can anyone explain the wiring that goes to the fuel pump? I want to make sure the truck is wired up correctly.
TIA, mo Any wiring diagrams for the Pups?
Re: can someone help me out with wiring?
[Re: mobetta]
#917730
11/28/08 12:16 AM
If no one answers here, go to.... http://www.isuzupup.com/index.phpThey are pretty knowledgeable on those engines. HTH Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4 NEVER give up...
[Re: mobetta]
#917731
11/28/08 02:47 AM
YOU ONLY NEED ONE WIRE TO THE SOLINOID ON THE BACK OF THE INJ PUMP IT MUST HAVE 12 VOLTS TO OPEN, THEN YOU NEED TO HAVE NO MORE THAN 6-7 VOLTS ON THE GLOW PLUGS FOR NO MORE THAN 6-8 SECONDS, AND IT SHOULD START RIGHT UP , JERRY
[Re: JLEMOND]
#917732
11/28/08 11:10 PM
so putting 12 volts to the GP's is bad? what is a good way to drop it to 6-7 volts??
got juice to the fuel selnoid, but no fire....
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6037 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-07-16 03:24:30 UTCValid HTML 5 and Valid CSS
