can someone help me out with wiring? #917729 11/27/08 03:44 PM
mobetta Offline OP
swapped a 2.2 C223T into a toyota, now when it comes down to starting the thing, it wont.
so can anyone explain the wiring that goes to the fuel pump? I want to make sure the truck is wired up correctly.
TIA, mo
Any wiring diagrams for the Pups?
Re: can someone help me out with wiring? [Re: mobetta] #917730 11/28/08 12:16 AM
Van Offline
If no one answers here, go to.... http://www.isuzupup.com/index.php
They are pretty knowledgeable on those engines.
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: can someone help me out with wiring? [Re: mobetta] #917731 11/28/08 02:47 AM
JLEMOND Offline
YOU ONLY NEED ONE WIRE TO THE SOLINOID ON THE BACK OF THE INJ PUMP IT MUST HAVE 12 VOLTS TO OPEN, THEN YOU NEED TO HAVE NO MORE THAN 6-7 VOLTS ON THE GLOW PLUGS FOR NO MORE THAN 6-8 SECONDS, AND IT SHOULD START RIGHT UP , JERRY
Re: can someone help me out with wiring? [Re: JLEMOND] #917732 11/28/08 11:10 PM
mobetta Offline OP
so putting 12 volts to the GP's is bad? what is a good way to drop it to 6-7 volts??
got juice to the fuel selnoid, but no fire....
Re: can someone help me out with wiring? [Re: mobetta] #917733 11/29/08 02:33 AM
bamashooter Offline
This supports what JLEMOND was referring to regarding the volage and duration of current to the glowplugs.
http://autorepair.about.com/od/enginerelateddiyjobs/l/aa081404b.htm
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6054 MB (Peak: 0.6694 MB) Data Comp: Off Server Time: 2026-07-16 08:53:02 UTC
