Page 1 of 3 1 2 3
Help! alternator swap out..can't get it out ! #918543 12/03/08 01:20 AM
MAC Offline OP
87 4Runner 22re with power steering.
Charge and brake dash lights came on so I'm swapping in my spare alternator. Got the bolts out (lower long one gave me quite a fight). Is it possible to get this dang thing out through the bottom without taking more stuff apart? i've tried every orientation I think, and can't get it through...Top is no option at all.
Re: Help! alternator swap out..can't get it out ! [Re: MAC] #918544 12/03/08 02:02 AM
missouriman Offline
lower radiator hose needs to be removed.
I have gotten it out before with out doing it.
but I have also caused a leak in the radiator.
It will come out the top. but it is like one of those puzzle things. got it out but could not get it back in.
make sure that it is bad. a few times I have pulled the connector out, oiled it up and put it back in and it worked.
Re: Help! alternator swap out..can't get it out ! [Re: missouriman] #918545 12/03/08 02:07 AM
missouriman Offline
now, I get it out by removing the steering shaft!!! but I cut the fender to get easy access to the steering box.
Re: Help! alternator swap out..can't get it out ! [Re: missouriman] #918546 12/03/08 07:12 AM
MAC Offline OP
Yup, lower hose did it. A pain to have to drain the radiator just to pull the alternator. Thought I had gotten it out of my pickup w/ same engine back a while without removing that hose but I must be mistaken.
I did check the connector and it seemed not to be the problem. Have to pick up a brush set and have the pulled one ready to go when I need it...
wow, with that cut fender it's a snap.
Thanks guys.
Re: Help! alternator swap out..can't get it out ! [Re: missouriman] #918547 12/03/08 07:16 AM
kewlynx Offline
Quite the trim job there MoMan!
If you don't have PS on the truck, then it's not a big deal. When I picked up my '83, the PO had removed the torque rod bolt and didn't put the dayem thing back in; I figured, for this chore. Managed to find one off an old frame before it left my friend's place.
**ubi apis- ibi salus**
Re: Help! alternator swap out..can't get it out ! [Re: kewlynx] #918548 12/05/08 03:45 AM
Buck Offline
To get it out the top I had to remove the radiator shroud, and fan. Had mine go out on the base, so no option of removing the radiator hose.
84 Ext. Cab Pickup.
Re: Help! alternator swap out..can't get it out ! [Re: Buck] #918549 12/05/08 10:47 PM
MAC Offline OP
Thanks Buck. I will try that next time. I will be happy to take off the shroud and fan to not have to drain the radiator. The plastic drain plug on my rad is a course sloppy thread and the stream coming out is all over h**l...makes a da*m mess in the garage...don't want my animals to find any to lick up either.
Re: Help! alternator swap out..can't get it out ! [Re: MAC] #918550 12/06/08 08:06 PM
A
allochris Offline
ok. i'll have to do take off my alternator tomorrow with my 91 22re. (w/ power steering)
What's the consensus for easiest/fastest R&R?
-Trim fender & remove steering shaft
-Rubic's cube from the top
-Rubic's cube from the bottom
-Undo fan & shoud
-Drain & remove lower rad hose
Note: I have a dog in the backyard & it's FREEZING out...-5 degree celcius...buurrrrr....
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Help! alternator swap out..can't get it out ! [Re: allochris] #918551 12/07/08 02:40 AM
missouriman Offline
well if you cut the fender out..
umm look behind it first. I cut the bottom off my wifes radiator over flow bottle..
Re: Help! alternator swap out..can't get it out ! [Re: allochris] #918552 12/07/08 04:33 PM
Richards19884x4 Offline
It's easy on a 91.
Step 1: Remove truck.
Step 2: Rebuild Alternator
Step 3: Reinstall truck. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.121s Queries: 16 (0.117s) Memory: 0.6349 MB (Peak: 0.7586 MB) Data Comp: Off Server Time: 2026-10-24 03:16:45 UTC
