Page 2 of 3 1 2 3
Re: DOHC head interchange question [Re: justice] #918634 12/11/08 03:03 AM
1
1986powerram50 Offline
I want to confirm weather or not the 3.0 DOHC and 3.5 DOHC heads are interchangeable.
Ok....... lil bit of a threadjack but...... hopeufly Justice will forgive me
So what about the SOHC 3.0 like whats in my Mighty Max???? I guess I misread this when I saw it the first time or is there any head upgrade for that motor?
--keRby
Ad Inexplorta
Re: DOHC head interchange question [Re: IncorpoRatedX] #918635 12/11/08 03:46 AM
justice Offline OP
The water crossover pipe is what concerns me a little. But The Diamante DOHCs are plentifull in the yards here and easier to find than a DOHC Montero. Also are the left and right banks interchangable on the DOHC engines? Since I'm lazy, It would be easier to pull two different front heads off two seperate cars maybe not the best idea, but a thought...
Not at all, you'd have the ports backwards...
pull two 'front' heats and you'll have two passenger side heads which would put the exhaust ports on the inside on the driverside... <img src="/forums/images/graemlins/scared.gif" alt="" />
Not if you can turn the head 180 and flip the cams over like you can on the 12V 3.0, which is why I asked the question. But with the water crossover pipe this is probably not the case with the 24V DOHC heads.
Re: DOHC head interchange question [Re: 1986powerram50] #918636 12/11/08 03:52 AM
justice Offline OP
All variants of the mitsu 6G72 12V 3.0 heads are all pretty much the same but there are some variants in the cams, cam sprockets, and valve cover bolt boss. But there is no bolt on upgraded 12V head that I'm aware of.
Re: DOHC head interchange question [Re: justice] #918637 12/11/08 05:00 AM
FrankR Offline
Correct - and AFAIK, there's no "bolt-on" anything for the 3.0L 12v SOHC engine that will make more power. There are a couple of header sets manufactured, but I doubt much gain would be realized from them - maybe a little.
If you want to spend a day with a die grinder, the heads can be ported and gasket matched to the manifolds which might help a little. I've done that to mine, but I don't know if it does much more than makes me feel like I did something to "make it better".
Frank
Re: DOHC head interchange question [Re: FrankR] #918638 12/11/08 08:29 AM
I
IncorpoRatedX Offline
I'm going to check tomorrow on a set of 3kGT twin turbo heads, if swapped how you've explained, the heads externally look like they'll work, but im going to have to check out the cam situation.
I'll post info as i find out, unless you've actually done this or have a set of DOHC heads.
V45W - 1999, 3.5 sohc, winter package
L042G- 1987, 2.6 carb, auto - Cylon Raider
A112 - 1973 Galant Wagon - 4G63 Turbo, 5 speed
L023G - 1983, 2.6 carb, 5 speed manual 4WD
L028 - 1983, 4D55 turbo diesel 2WD
Re: DOHC head interchange question [Re: IncorpoRatedX] #918639 12/11/08 12:11 PM
FrankR Offline
I've placed a set of DOHC heads side-by-side and compared them to SOHC heads..... same with DOHC/SOHC blocks. You'll find that the DOHC heads will bolt on, but there is a small cooling water passage between the exhaust valves on the DOHC heads that is fed from the DOHC block. The SOHC block does not provide the supply for that passage.
Frank
Re: DOHC head interchange question [Re: 1986powerram50] #918640 12/14/08 09:23 PM
TobyB Offline
The sohc heads are entirely reversible, in my experience with
4 or 5 motors... the CAS/dizzy mount's bolt- on,
and all the bosses have been drilled.
Even on various Chrysler products
t
'89 V6 4dr- '4- Doris'
Re: DOHC head interchange question [Re: IncorpoRatedX] #918641 12/18/08 06:36 PM
Hans_GZP Offline
93+ 3000GT/Stealth heads are interchangeable with SR heads. They are identical and can be swapped from side to side (just spin them 180 degrees and swap locations for the coolant block off plate). The castings are the same and so are all of the mounting holes.
96 Montero SR
94 Dodge Stealth TT
92 Mitsu Galant VR4
91 Mitsu 3000GT
95 Mitsu 3000GT, carbon black, for sale
95 Mitsu 3000GT, white, for sale
92 Mitsu 3000GT VR4, silver, for sale
Re: DOHC head interchange question [Re: Hans_GZP] #918642 12/18/08 06:56 PM
V
vr4 Offline
who let you in hans?
<img src="/forums/images/graemlins/smile.gif" alt="" />
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: DOHC head interchange question [Re: Hans_GZP] #918643 12/18/08 07:07 PM
justice Offline OP
Thanks for the info. Thats what I was curious about.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6468 MB (Peak: 0.7741 MB) Data Comp: Off Server Time: 2026-07-15 04:12:05 UTC
