1990 another rear window question #918700 12/04/08 04:40 AM
VAHunter17 Offline OP
just picked up a 1990 3.0auto 4runner (im new to 4runners but not to pickups and tacomas) and the rear window does not go up OR down with the center console switch nor the key switch on the tailgate. I can hear a relay click when i press the down button on either switch and i dont hear anything when i press the up button switch.
I checked the motor. I replaced all 4 relays in the module. and the child safety lock is not on. Any suggestions guys???
Thanks,
Buddy
Re: 1990 another rear window question [Re: VAHunter17] #918701 12/04/08 04:47 AM
G
Greg_Canada Offline
Rear wiper on? I had that problem <img src="/forums/images/graemlins/ignore.gif" alt="" />
89 4Runner
Re: 1990 another rear window question [Re: Greg_Canada] #918702 12/04/08 05:26 AM
What? I tried wigglin' the wiper and putting pressure on the tailgate but still did nothing.
Did you fix yours?
'98 Tacoma TRD ext.cab 2.7 5spd 6inFabtech sus w/ 33x12.5.15 TrxusSTS on 15x10 DC-1 (Black)
'90 4Runner 3.0auto stock as of now
Re: 1990 another rear window question [Re: VAHunter17] #918703 12/04/08 05:58 AM
G
Greg_Canada Offline
When did it break?
My wiper switch was on and i turned it off, then it worked.
there is also a limit switch on the wiper that will stop the window from moving.
89 4Runner
Re: 1990 another rear window question [Re: Greg_Canada] #918704 12/04/08 12:07 PM
wiper switch is not on. I dont know when it quit. I just bought it and he kinda sounded like it has been a while.
Re: 1990 another rear window question [Re: VAHunter17] #918705 12/04/08 04:22 PM
how can i check to make sure the wiper home switch and the tailgate close switch is working properly and is there anything else i can check that would keep the window from working? Thanks again
Re: 1990 another rear window question [Re: VAHunter17] #918706 12/05/08 12:38 AM
Adam F Offline
97 4R, stock, daily driver
Re: 1990 another rear window question [Re: Adam F] #918707 12/05/08 02:48 AM
G
Greg_Canada Offline
Hrm, if you jump in the back and hook up 12v to the motor you can bring it down. if that doesnt work, your motor is screwed... but once you bring it down you can work on it more easily... might want to do that...
89 4Runner
Re: 1990 another rear window question [Re: Greg_Canada] #918708 12/05/08 04:25 AM
so if i unplug the wiper and the tailgate then the window should work if the window wiring is good? If so, can anyone hint me to those plugs? Thanks,
Buddy
Re: 1990 another rear window question [Re: VAHunter17] #918709 12/05/08 06:22 AM
kewlynx Offline
Here's another good one to bookmark:
http://www.geocities.com/dkwalker/4runner.html#downloads
At the very least, you want to make sure you're getting power back there as mentioned. Hopefully it's just wiring.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6423 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-11-03 13:35:10 UTC
