Cheap steering parts #918978 12/04/08 12:34 PM
Y
yankneck696 Offline OP
http://search.stores.ebay.com/World-Suspension
Now for my question... I know that the idler arm is better on the Gen II's. Can I get the pitman arm/idler arm combo & use them both on my 89 V6 without too much modification? Are the Gen II tie rods usable/better?
I need to rebuild everything in the front end of mine & see this as a good alternative.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Cheap steering parts [Re: yankneck696] #918979 12/05/08 12:38 AM
KrzyDav Offline
The pitman are on the 90 and 89 SWB and the 89 LWB have different thinner splines on them than 90 0n.
I want to put a Gen 2 idler arm on mine, too. The one's I've found seem to have a little play in them , but that could be an optical illustion from the angle I have to look at them half burried in the sand dune and all.
I don't rock crawl so I don't think the Gen 2 arm would do damage to other parts of my front susp.
dave h.
Re: Cheap steering parts [Re: KrzyDav] #918980 12/05/08 12:42 AM
justice Offline
from holding two tie rods side by side the gen 1 and 2 appear identical.
Re: Cheap steering parts [Re: justice] #918981 12/05/08 01:01 AM
Y
Cool... So, just stick with the gen I stuff, except for the idler arm from a Gen II? ( I can get the whole arm for what the stealer wants for the bushings)
I'm gonna put the 5.0 in after the newyear & want to replace all of my loose steering before getting back on the road.
Gen I:
tie rod ends
lower ball joints
pitman arm
Gen II:
idler arm
UCA's w/ ball joints
Any other suggestions?
Ed
Re: Cheap steering parts [Re: yankneck696] #918982 12/05/08 01:06 AM
justice Offline
Gen 2 steering box with pitman. I have one for my 89 but have not installed it yet.
Re: Cheap steering parts [Re: justice] #918983 12/05/08 01:52 AM
KrzyDav Offline
I think the Gen 2 box has a different ratio 3 total turns of the wheel compared to 3 1/2 on gen 1 . Don't know if that much would make too much difference for a SWB.
dave h.
Re: Cheap steering parts [Re: KrzyDav] #918984 12/05/08 02:31 AM
justice Offline
big differnce when turning 33" tires at a standstill at idle.
Re: Cheap steering parts [Re: justice] #918985 12/05/08 12:27 PM
Y
OK... I might do the box.
I also remember a while back, someone found aftermarket CV boots. Mine are still intact, but pretty stiff.
Ed
Re: Cheap steering parts [Re: justice] #918986 12/06/08 12:27 AM
KrzyDav Offline
I was thinking on the ratio about too quick a ratio for driving a SWB on pavement.
Also the 91 LWB has a heavier box that bolts up the same.
The Gen 2 ,?I thought you had to do some drilling?
dave h.
Re: Cheap steering parts [Re: yankneck696] #918987 12/06/08 02:14 AM
Gen II dual-piston calipers.
[hijack]
Hey Ed, how goes the museum? We have last minute plans and are heading to S'ota for Christmas.
[/hijack]
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6401 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-07-16 23:15:19 UTC
