Troublecode 41 for MFI #918990 12/04/08 02:53 PM
4x4david Offline OP
I am getting a troublecode 41 (open/closed circuit in the generator field) when I use a scan tool. A little history. My jeep is 1989 and I just installed the Mopar MFI kit. The MIL light is lit and I tried to erase the code since I thought it was a leftover code from the initial install but the code 41 will not erase. Therefore, there is a problem
Getting the Wheeling fever...
4x4david
Re: Troublecode 41 for MFI [Re: 4x4david] #918991 12/04/08 03:54 PM
BigJim Offline
How many volts is the thing putting out? Might be as simple as a burnt alternator.
Re: Troublecode 41 for MFI [Re: BigJim] #918992 12/05/08 08:21 AM
4x4david Offline OP
Battery Voltage = 14.2 per scan tool
Charge Goal = 13.8 per scan tool
4x4david
Re: Troublecode 41 for MFI [Re: 4x4david] #918993 12/05/08 12:43 PM
BigJim Offline
That's a normal reading...run it!
Re: Troublecode 41 for MFI [Re: BigJim] #918994 12/06/08 08:10 AM
4x4david Offline OP
Thanks BigJim. That is what I was told. However, when I try to erase the code using my AutoXray 6000 scan tool I can not erase the code 41. This tells me there is something still wrong. Any suggestion ?
4x4david
Re: Troublecode 41 for MFI [Re: 4x4david] #918995 12/07/08 07:18 AM
Bigbird79 Offline
have you double checked all of the electrical connections since you installed the MFI? Maybe something is loose, and is tripping the code...
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: Troublecode 41 for MFI [Re: Bigbird79] #918996 12/11/08 05:25 AM
4x4david Offline OP
After long research on the internet, I found a website that told me just that. Possible bad connection or loose wire. I plan to recheck all alternator connections and put dielectric grease on all connections. Thanks for the help
4x4david
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6099 MB (Peak: 0.6875 MB) Data Comp: Off Server Time: 2026-07-11 08:28:56 UTC
