Fuel pump replacement.. #919002 12/04/08 10:15 PM
L
ldrmn Offline OP
So im sick of double cranking my truck so im gonna replace the fuel pump. I have a 99 cherokee XJ.
I work in a body shop and pulled up the R&I on the pump on ALLDATA. It says that the plastic cap NEEDS to be replaced when you replace the fuel pump. Is that REALLY necessary?
Also a tech at work has 2 Walboro fuel pumps, bran new. I compared the actual pump with pictures online(his pump is for a mustang) and the pumps themselves look identical, if i can get away with not spending $100 that would be great.
Has anyone else used a generic fuel pump? And is it really necessary to replace the cap/grommit?
Re: Fuel pump replacement.. [Re: ldrmn] #919003 12/05/08 01:03 AM
BigJim Offline
Seversal years ago I used a generac pump when the damn thing went out in the wilderness.. About 90 miles away I found a generic auto parts house and they had a generic pump...which they assuered me worked fine on many models. I installed it in the thorny dirt where it went south.. As far as I know it is still in there working fine.
And NO! You don't have to install a new cap..
Re: Fuel pump replacement.. [Re: BigJim] #919004 12/09/08 05:23 AM
playinmud Offline
hijack. the check valve or whatever its called that keeps the fuel from draining back into the tank when the jeep is shut off. is that in the pump itself or in the pump/sending unit combo? my guage is accurate so if i can get away with just a pump that would be a lot cheaper.
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: Fuel pump replacement.. [Re: playinmud] #919005 12/09/08 04:31 PM
Brown81CJ5 Offline
I don't know about the TJs, but in my CJ5 it is seperate from the pump...up inside the driver rear fender well. But then again my Jeep has a mechanical fuel pump.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Fuel pump replacement.. [Re: Brown81CJ5] #919006 12/09/08 06:12 PM
4x4Wire Offline
The 4.0L does not have a fuel-line check valve. The FI fuel rail is pressurized once the ignition key is turned on and the fuel pump started.
There is a fuel return line that will allow fuel to drain out of the FI fuel rail once the pump is shut off.
For a fuel injected system to function properly, the tank must build an internal pressure and maintain it.
There is a check-valve that functions to block flow of fuel in event of roll-over or extreme off-camber when fuel could flow out the filler tube. The CJs have vapor recovery line connected to it. Depending on vehicle age, configurations are different. The valve is located near the filler neck.....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Fuel pump replacement.. [Re: 4x4Wire] #919007 12/09/08 11:13 PM
BigJim Offline
John... Its most likely the fuel regulator/filter (aka anti-drain back valve) In the top of the fuel pump is the anti-draniback assembly. This thing gives lots of Jeeps a hard start condition.
I have found new ones on eBay for as little as $30. Yeah it is a chore to replace them and many guys just go ahead and replace the complete pump.. But if the time and labor aren't a problem the price is cheap to stop the hard start condition.
The thing holds the pressure when the engine is turned off so the next start will have instant pressure. If one leaks the drainback causes a lack of pressure for several seconds during the restart. (depending on how long since the last start).
Re: Fuel pump replacement.. [Re: BigJim] #919008 12/09/08 11:21 PM
4x4Wire Offline
It has been over 6 years since I had to replace one (on my 89 Cherokee).
My recollection is it was one unit with a separate screen filter.
Dropping an almost full tank to allow access to the top is a pain....
John Stewart
Editor - 4x4Voice
Re: Fuel pump replacement.. [Re: 4x4Wire] #919009 12/10/08 05:28 AM
playinmud Offline
mine does not have a fuel return line. the guage will drop down to zero after like 30 seconds of the jeep being shut off. so big jim you think id get away with just replacing the pump? i have to do the key on and off thing like 3 times before it will start otherwise it cranks for a good 10 seconds. and it only pumps out at 45psi which is the lowest psi for spec.
Re: Fuel pump replacement.. [Re: playinmud] #919010 12/10/08 06:02 AM
BigJim Offline
As long as it doesn't seem to run out of fuel at high rpm, as if a filter were stopped up, I'd be replaceing the anti-drainback or if a lot of miles on the pump I'd prolly simply replace the entire pump assembly..
Just from your posts I'd think that would fix your problems.
Re: Fuel pump replacement.. [Re: BigJim] #919011 12/12/08 06:44 PM
playinmud Offline
it doesnt run out fuel at high rpm. if i buy just the replacement pump instead of the whole sending unit i would also replace the filter otherwise the new pump wouldnt be under warrenty plus is only 7 dollars and i know the new filter would be clean. i do notice that when i start it when its cold it idles rough. it had a complete tune up about two years ago. could it be idleing rough because theres air in the system when the pump first builds up pressure?
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6369 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-11-02 08:45:47 UTC
