Re: Fuel pump replacement.. [Re: playinmud] #919012 12/15/08 02:30 AM
BigJim Offline
I kinda doubt the rough idle is caused by the fuel pump.. But maybe so?
Re: Fuel pump replacement.. [Re: BigJim] #919013 12/15/08 09:29 PM
playinmud Offline
what could be the cause of it then? it only happens sometimes and it only does it when its really cold outside, but it'll happen when then engine is hot or cold.
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: Fuel pump replacement.. [Re: playinmud] #919014 12/15/08 11:16 PM
BigJim Offline
Could be that 2 year old tune-up! If COLD translates to WET I'd be looking at wires.
Re: Fuel pump replacement.. [Re: BigJim] #919015 12/16/08 05:48 PM
playinmud Offline
hmm, its winter, so that might be it. it never did it in the summer time and the fuel pump was bad then too. wires/ sensors should i be looking at? oxygen sensor in the header was replaced a couple months ago. you know what come to think of it, its the exact same rough idle that it did when the old oxygen sensor went bad. but this happened at random times. it went away for a while but now its doing it again and it happens at startup. ill half to check the connection on this one and make sure its tight in the header
Re: Fuel pump replacement.. [Re: playinmud] #919016 12/16/08 08:04 PM
BigJim Offline
I had spark/coil wires in mind but the oxy could stand a ohm check also..
Re: Fuel pump replacement.. [Re: BigJim] #919017 12/17/08 05:44 AM
playinmud Offline
i just checked the spark/ coil wires about a month ago for a lab in school and they were the same they were two years ago when i put them on. i ohmed them when i got them because the place i got them from is known for bad parts. one time we got a pack of spark plugs from them for one of the forklift motors and 5 out of the 6 plugs were used. how would i go about ohming the o2 sensor? if im thinking right i think you ohm it and then heat it up and ohm it again and it should be lower right?
Re: Fuel pump replacement.. [Re: playinmud] #919018 12/17/08 06:24 AM
BigJim Offline
Cold it shouldn't make volts. Hot should be between .85 and one volt. Check it cold first and then leave the meter attached and heat it with a propane flame. It should steady near .9 or above let it cook for a while to see if it blinks while hot... then take the heat away and the volts should go away.. I'd heat it 4 or 5 times in a row to see if it does the same thing time after time.
Remember it is located in a very hot place, so a nice red color won't hurt it.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.011s) Memory: 0.6203 MB (Peak: 0.7145 MB) Data Comp: Off Server Time: 2026-07-15 12:47:05 UTC
