Over heating after head replacement
#919457
12/08/08 02:14 AM
After replacing my head with a race head fron engbldr my 22-re will over heat after 1-2 minutes on the freeway. I opened up the radiator and there is a brown sludge in there. It may be crap/oil getting into the channels when I was cleaning the block or maybe because I messed up putting the head on and oil is getting in there I don't know. I had a shop pressure check and flush the radiator. They said it held pressure but forgot to flush it. There is no sign of water on the dip stick. I replaced the cap and thermostate it had no effect.
Any tips on how to get this thing from over heating?
Also on these RV heads do I use the standard BTDC 5 degrees timing?
---------------------- '87 4Runner
Re: Over heating after head replacement
[Re: Chunky]
#919458
12/09/08 10:04 AM
Brown sludge is not good, get it cleaned up as your first step & *then* start other tests.
Dave
[Re: Chunky]
#919459
12/10/08 02:27 AM
Sounds like it could be a bad head gasket. Have your mech (or you) do a leak-down test, to confirm or eliminate. Relax: it's not that bad!
'80 4X4 Longbed
[Re: Chunky]
#919460
12/10/08 04:04 AM
Lemme guess- didn't change the oil/filter afterwards, no?
*Purge coolant system. *Change oil and filter-keep in mind the drain plug boss doesn't allow about 1/2" of stuff to finish draining. *Do a leakdown/compression test as suggested.
Set the basic timing with that cam, then dial in your sweet spot for it. Don't ferget your jumper!
[Re: kewlynx]
#919461
12/10/08 02:44 PM
Good call Kewlynx.
Did you remove the timing cover when you did the head gasket? One time, as I pulled the cover, excess coolant ran down the front of the oil pan, causing sludge. Freeked me out for a minute until I realized that I did that.
[Re: Staceman]
#919462
12/11/08 02:20 AM
The radiator guy flushed it twice, he said there was a bunch of oil in there which was slowing the water pump down.
It hasn't come back yet. The radiator was pressure tested and it turned out ok. I think what happened was the oil pooled up below the cam poured out on too the block and went down into the coolant jackets. I slipped when I was removing the head and it all poured out the back side.
I didn't think I got much in there, but I guess I was wrong.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6092 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-07-15 02:06:48 UTCValid HTML 5 and Valid CSS
