Feels like fuel exhaustion... #919615 12/08/08 11:29 PM
walkingman Offline OP
Hi all,
My '88 Raider runs great around town. Up at highway speeds though, I begin to get what feels like fuel exhaustion after 10-15 minutes. The engine will cut completely in and out. If I back off 5-10 mph, I can drive another 5-10 minutes before it starts to happen again. I can continue slowing to keep under the "shelf" where the engine begins to cut in and out, until I can only maintain around 30 mph. If I pull over and completely stop for 3-5 minutes, when I get going again I'll get another full 10-15 minutes before the problems start.
Again, around town it's great all day.
It feels just like fuel exhaustion, which made me wonder if something is up with the Weber carb. Or maybe the cat? A shop looked at it today and said I had a burned valve on the #2 cylinder. That may be, but it doesn't seem like a burned valve would cause the engine to run fine around town, and cut out only after several minutes on the highway.
Whatcha think? thnx.
None at the moment
Re: Feels like fuel exhaustion... [Re: walkingman] #919616 12/09/08 01:05 AM
FrankR Offline
If you don't know when it was last replaced, replace the fuel filter and see what happens.
Frank
Re: Feels like fuel exhaustion... [Re: walkingman] #919617 12/09/08 10:02 PM
0778drz110 Offline
I also had that on mine. I replaced the pcv valve and the fuel filter and it was fixed for under $10 <img src="/forums/images/graemlins/kewl.gif" alt="" /> I don't know which one fixed it but they both needed replacing anyways.Hope this helps
Re: Feels like fuel exhaustion... [Re: 0778drz110] #919618 12/10/08 03:21 PM
Thanks fellas. I should have mentioned I did replace the fuel filter... no change. I'll check out the PCV valve.
None at the moment
Re: Feels like fuel exhaustion... [Re: walkingman] #919619 12/10/08 11:25 PM
Fuel pump? Still sounds like a fuel delivery problem to me.
Re: Feels like fuel exhaustion... [Re: fasteddy] #919620 12/11/08 01:42 AM
0778drz110 Offline
It could be. On mine it would start shaking and bouncing the truck then it would stop. All I did was replace the pcv valve and it hasn't done it since. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.015s) Memory: 0.6122 MB (Peak: 0.6821 MB) Data Comp: Off Server Time: 2026-11-04 20:00:36 UTC
