Questions on Mighty Max auto hubs and master clinder #919806 12/10/08 12:12 AM
StarquestRescue Offline OP
Will Auto lock hubs from a 87 4 cly fit a early 90's 6 cly? Links to where to buy manual lock hubs for v6?
My 87 MM master cylinder is leaking. I have a brake booster from a v6 first Gen Montero 4 door. What year/ model master cylinder should i order? Will the brake lines fit up ok. Do i need a reservoir or any thing else?
Thanks
Mits owner since 1980
88 Power Ram 50 turbo intercooled. Sport cab auto 4.22 gears rear posi. Rust in peace.
Re: Questions on Mighty Max auto hubs and master clinder [Re: StarquestRescue] #919807 12/10/08 12:17 AM
Auto hubs will fit. Big Blue has some Aisin manuals for sale in the Classies. Summit carries the Superwinch hubs.
The later master cylinder has a different output for the front brake line, slightly different angle. The 4-door power booster is larger in diameter but should interchange.
I have a 4-cyl master cylinder that I'm not going to use. Let me know if it's needed.
Russell
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5883 MB (Peak: 0.6365 MB) Data Comp: Off Server Time: 2026-07-09 16:46:07 UTC
